Old 04-26-2008, 09:02 PM   #1
AdRock's Avatar
Cooling system info
I'm doing a coolant flush pretty soon and plan on switching to a 180' T stat from the stock 197'. Now, I can't remember the stock temps that the low & high cooling fan comes on at. Also, I've looked all over the damn place and can't find the temps I should set the fans at for low & high after the 180 is in there. I'm think around 185' for the low speed & 190' for the high speed.
I know someone here knows right off the top of their head. Or can at least point me in the direction of some actual useful info.
'02 Stang GT
And let me tell you something
Cause you can't bring me down
Old 04-26-2008, 09:11 PM   #2
re re
Trader Rating: (14)
Why do you want to change it from stock? The t-stat alone will drop it to an extent.
I have mine at 190/200 low/high
Originally Posted by ezblonde
Old 04-26-2008, 11:45 PM   #3
AdRock's Avatar
I just want to make sure I move everything down in relation to the trop in t stat temp.
For instance. I did find on AllData that the stock 195 t stat starts to open between 192-199 and is full open at 219. So:
195 tstat opens 192-199 full open at 219
low fan at ? high fan at ?
so I would assume
180 tstat opens 177-184 full open at 204
If I can find the stock fan numbers then I can plug in the new numbers for the 180 and everything will still be the same in relation to one another just at the lower temps.
'02 Stang GT
Old 04-27-2008, 07:05 PM   #4
blk01gt's Avatar
Send a message via AIM to blk01gt Send a message via Yahoo to blk01gt
how can you tell if ur fan is on high or low cuz i dont think mine goes into high or if its stuck in high it seems only 1 spd lol
blk01gt is offline   Reply With Quote
