Old 04-04-2008, 11:27 AM   #1
Send a message via MSN to 87fox2e
couple codes, need some info on
im throwing a code for vapor canister purge solenoid, basically what is it for and if i dont replace it right away what is it going to effect. i know its part of emissions and thats about it. also throwing code for air temperature or vain temperature high signal output. how do i fix that one and what does that effect? i did try doing some searching, but maybe i just couldnt find it. thanks
87 GT hatch, 5spd.
87fox2e is offline   Reply With Quote
Old 04-04-2008, 11:32 AM   #2
☆★LSS★☆
87 GT hatch, 5spd.
Is this one of the codes?
ACT or IAT-Intake Air charge temperature sensor
Old 04-04-2008, 11:54 AM   #3
no i wish it was then i would know what it was. but its "air intake tempature or vain air tempature signal high output". the code numbers im throwing are 54 memory, 85, and 98. these are KOEO codes.
