Happy Halloween!
CPS FTL *vent*
OMG CPS is killing me, got our bill in for this month and it is crazy high still at about 250 for the month, same as last, but typically we only do about 150 in the summer months maybe 175 the most. This is crazy!!!!!!
*Mrs. 96greengt*
Killing all the newbs with the IW!!!
Same here, we run our AC at 73 and it cost us $234 last month. Since then, we raised it to 76 and have most of the fans on. We haven't got this month's bill in yet, but more than likely it probably isn't going to make that much of a difference.
VICTORY!!!!!!!!
Aprils Bill was $190 with ac aroudn 74
May Jumped up to $300 with ac around 74 June was at 200 with ac around 78 Every degree below 78-80 degress will equal about a 10% increase in the bill. Also keep in mine CPS charges more per killowatt in the summer because of demand. if they keeped prices low everyone would use WAY too much electricty in the summer because of the heat. its supply and demand. The best thing is to leave a/c on 78 and get fans. Fan lower the temp between 3-5 degrees
Go SPURS Go - Go on Keep Losing! ![]() ![]() |
#5 | |
Happy Halloween!
*Mrs. 96greengt*
Evil Angel
Well there was a rate increase wasn't there?
And I don't think more fans will make up for less A/C in the long run because they still use electricity, but that's just my opinion.
God's gift to Dell
if you pchase energy efficiant fans (like I did, from Lowes (harbor breeze 52" fans), it WILL lower your cost of energy. Yea, they use energy, but your AC uses MORE energy if it has to work harder to cool and come on more frequently..
I keep my AC on 73 degrees 24/7, and my electricity bill is $109. That is cooling a 1700 sq ft house, not a 500 sq ft apt for those of you who think im kidding
#8 | |
VICTORY!!!!!!!!
Straight from the CPS energey website Heating and Cooling Efficiency Keep room temperature between 78 and 80 degrees. For each degree cooler, costs can increase 7 to 10 percent. Consider using a programmable thermostat. Set it at a higher temperature while you’re at work, then program it to be a comfortable temperature when you return home. Try our Peak Saver Thermostat Use ceiling fans to circulate air and make a room feel cooler. Don’t forget to turn off fans when you leave the room! Check your air filter every month, especially during the winter and summer, and replace dirty filters that make your system work harder and waste energy. More Heating and Cooling Efficiency tips
#9 | |
VICTORY!!!!!!!!
#10 | |
Evil Angel
EDIT: This is with all electric appliances as well. And thermostat typically set at 76.
#11 | |
VICTORY!!!!!!!!
#12 | |
Evil Angel
how long?
mine went from 150 to 335 and i just got my new bill and its 300... this shit is killin me...thank god Timewarner saved me about 60 so that will help!
HAS ANYONE SEEN MY HEB BAGS???
Doesn't this all REALLY stem from oil though? Damn oil BS!!!! Check your water heaters also.
96 SVT#6858 of 7496 http://videos.streetfire.net/video/9...bra_193899.htm Click the link below. Inventory updated regularly. http://www.autotrader.com/dealers/dd...um_records=100 210-658-6296 or call toll free 1-866-221-1190 |
2001 Oxford White Mustang GT
We are enrolled in the Fixed bill program also known as the budget plan. They average a year's worth of use and you pay the same each month. Based on our last average we always pay 159 a month. That's with the air set at 78 and pool pump running for 14 hours everyday. We are up for renewal on the plan and our new averaged rate will go up to 189 for the next 12 months.
They have another program that lets you lock in the rate you are being charged. I think it's called the fixed rate program. Budget Payment Plan
#16 |
Yeah, my house is on the Averaged Annual Billing thing ... I pay about $150 year 'round. 1,200 square foot house with a pool pump running about 8 hours a day and 2-4 ceiling fans on at all times.
I use a programmable thermostat, and have the house set to 78 when we are up and around ... 80 when no one is at home except the dogs ... and 63 at night when we are headed to bed. (I like it cold at night to sleep.) One of the biggest savings I have found is when I replaced my house's windows. I took 4 months off paying (on the averaged plan, that makes $600 saved the first year) my electric bill when we came up for our renewal. The windows cost $5,000 installed, custom-built; and we saved quite a bit the first year, dropping my annual average from $180 to $150 AFTER the hiatus in payments!!!!!!!!! My house has about 80% fluorescent lights, only using incandescent bulbs in the bathroom vanity mirrors -- chicks shouldn't apply make-up in flourescent light. Gas for heat and cooking and hot water. We have gone through the house and filled every outside-wall outlet with insulative material to reduce the heat transfer through the walls. We have a HUGE oak tree out front which shades our home in the afternoons. We have verified the weather stripping on the front and back doors to make sure that the amount of climate control escaping through those cracks is minimized. The only things we have not been able to do to my house has been to re-insulate the attic to an R-30+ value or to R&R the wall insulation to verify that it's a suitable value ....
We human beings are very funny: when something bad happens in our lives we say, "Why me? Why is this happening to me?" But when we wake up every morning and are alive and healthy and our family is well, we never say, "Why me? Why am I so fortunate?" 'Life isn't about how to survive the storm, but how to dance in the rain.' |
#17 |
☆★lSs★☆
you know what else is great for reducing your monthly energy bill?
Spray Foam Insulation We've been doing a ton of retro-fits recently.
![]() LSS Member #22 |
#18 |
Giving up
Jen I don't know how your bill could be that high, my parents have almost 3k square feet of A/C that runs 24/7 at 74 since there is allways someone home, and 14ft cielings, fans & about 3 computers that stay on and its less than 300/month.
#19 |
VICTORY!!!!!!!!
also depends on how energy efficient the houses are. energy star homes will have a bill about 40% lower than non energy star homes. Even if you hom is not energy star rated you might have a couple of those features to make the home more efficient. like low-e gas filled windows, better insulations, better rated A/C unit, tighter construction, better air ducts, etc. If you home was bulit after 2004, it is rated atleast to the 2004 International Residential Code (IRC) standards which would make your home 10-15% more efficient than a pre 2004 home.
#20 |
Our usage this year for June and July was lower than last year at this time yet the bill was a hell of a lot more . My last two bills were $254 and $256 versus about $170ish this time last year .
