Old 07-28-2008, 03:55 PM   #1
custome kb setup for 05-06 mustang and teksid block forged short block
im building a 325 big bore stroker and switching a bigger blower on my 06
Kit in cludes over 2000 in custom aditions
Sheet metal rear intake custom big bore inlet tube with 115 mm mass air
also will come with customers choice of boost levels 10-12 being all i would recomend on a stock short block.
kene bell 2.6H blower with 38 pound injectors kb boost a pump etc all included.
asking 5000.00 INSTALLED on your car and dyno tuned.
The kit was 5700.00 from kb without any of the extra aditions and install would normaly cost you 1100.00 + 500 for dyno tune and 389 for predator.
over 8500.00 total for this installed normaly kit has aprox 3000.00 street miles on it and made 756 rwhp on my car
I am also selling a forged short block for 3 valve modular
good for 900 horsepower and 7500 rpm
4340 steel crank
4340 steel rods
new bearings
new rings
New forged diamond piston low compresion 3 valve pistons NOT a flycut 2 valve piston but a custom true 3 valve piston with correct 3 valve valve reliefs
Fresh from machine shop balancer blue printed and ready to run
These are the same parts I make 865 rwhp and shift at 8000 rpm with in my 06 mustang.
The short block will be back from the machine shop Ready to install next week.
Asking 3400 for the short block. fresh ready to run all new parts and you get to keep your short block no core and get a stronger teksid block instead.
We can also make a deal on install of the short block if needed.
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 07-29-2008, 12:09 PM   #2
bump
bump
PSI
210-655-6546
performance shop.
