damn!! need help
well i was at work today and was gonna do a front brake job on my car but could not find my damn locking lugnut key, went home and looked everywhere! is there any way of taking off these lugnuts without damaging my wheels? Damn this pisses me off!!
Yes. a body shop or a tire shop can do it. Just have them take the lock off. They might do it for free if they have an hourly guy do it
yea discount has a set.. unless... are they oem? a dealer will have a set... i bet if you pay the parts dept. 10 bucks to borrow it in the parking lot and buy a new set from them...
They make a wheel lock removal set. I have one at work. Or in a fix I have taken a deep socket that fits real snug over the lock and beat it on with a BFH then use an impact to remove the lock.
![]() 1988 Mustang LX |
That trick works best if you DONT use an impact, but its the same concept as a universal set.
I just bust out the torch and sawz all !!! j/k
I have a looking lug removal kit in my box at work... I'd offer it to you or to even do it, but you ain't a local!
