Old 11-12-2007, 12:48 PM   #1
a.k.a. Hot Rod
tim7777's Avatar
Dead Pedal for a Fox Mustang
Does anyone make a dead pedal for the 1987 to 1993 Fox Mustang's?
Thanks!
Current Mustangs in the Stable
1966 Mustang Coupe, Straight 6 Engine, C4 Automatic Transmission
85% Restored – New interior, engine, tires / wheels, etc. – To many new parts to list.
1988 Mustang LX Hatchback, 5.0 Liter Engine, 5 Speed Transmission
Good Condition – New carpet, seat covers, white face gauges, etc.
tim7777 is offline   Reply With Quote
Old 11-12-2007, 04:28 PM   #2
4.6stanger's Avatar
Do you mean like a pedal cover?
Old 11-12-2007, 05:11 PM   #3
a.k.a. Hot Rod
tim7777's Avatar
Not really . . . I'm referring to the pedal to the left side of the front floorboard that you can place your left foot on after changing gears in a 5 speed vehicle. The pedal doesn't do anything but give you a place to put your foot after shifting gears.
Old 11-12-2007, 09:48 PM   #4
4.6stanger's Avatar
yeah i know which one your refering too, but i was thinkin you were wanting a pedal cover, but if iwere you id try a salvage yard.
Old 11-14-2007, 12:46 PM   #5
Marcus's Avatar
The '84-86 SVO's had them as oem and they were in the motorsport catalog for a while.
You might check Late Model Resto
'04 Cobra 'vert
'06 F150 S-Crew 4x4
Marcus is offline   Reply With Quote
Old 12-16-2007, 09:10 PM   #6
Sonic Blue 85's Avatar
Many of the GTs had them also, they should not be hard to find.
My car is an '85 sonic blue coupe with 302 bored and stroked to 364, Ported Twisted Wedge heads and a BXR intake, A9M ECM with a Tweecer, C4 with trans brake, Hoosier 275/60/15 drag radials, no power adders.
Sonic Blue 85 is online now   Reply With Quote
