Results 1 to 24 of 24
Thread: Disable/Enable the BeltMinder chime
    LoneStarStangs Addict Regular Member SALEENT76's Avatar
    Sep 2004
    Ft. Irwin, CA
    Chad's 2000 Mustang GT American Racer -- Disable/Enable Belt Minder
    Text from link:
    Disable/Enable Belt Minder -
    Before doing this you must make sure:
    Parking brake is set
    Gearshift is in Park (for auto) Neutral for Manual
    Ignition switch is OFF
    All doors are closed
    Drivers belt is unbuckled
    Parklamps/headlamps are in the OFF position. (Autolamps will not affect the procedure.
    1) Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE).
    2) Wait until the safety belt warning light turns off. (App. 1-2min)
    a. Steps 3-5 must be completed within 60 seconds or the procedure will have to be repeated.
    3) Buckle then unbuckle the safety belt three times, ending w/ the safety belt unbuckled. This can be done before or during the Belt Minder warning activation
    4) Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
    5) Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled.
    a. After step 5 the safety belt warning light will be turned on for three seconds.
    6) Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
    a. This will disable Belt Minder if it is currently enabled, or enable Belt Minder if it is currently disabled.
    7) Confirmation of disabling Belt Minder is provided by flashing the safety belt warning light four times per second for three seconds.
    8) Confirmation of enabling Belt Minder is provided by flashing the safety belt warning light four times per second for three seconds, followed by three seconds with the safety belt warning light off, then followed by flashing the safety belt warning light four times per second for three seconds again.
    9) After receiving confirmation the deactivation/activation procedure is complete.
    Last edited by TrueBlueVenom; 04-13-2007 at 04:11 PM. Reason: moved to How To section. added text from URL
    2002 Zinc Yellow Saleen #02-245
    Hellion Power Systems T-76 Turbo
    .20 VT Shortblock, 2v MPH Stage 3 Heads, MPH Turbo Cams
    612rwhp, 640trq, 20lbs of Boost
    Built and Tuned by MPH
    "Power in the Hands of a Fool"
    I dunno how! Regular Member 96greengt's Avatar
    Feb 2007
    N.E. SA
    you should have posted this over in the "How to" area....
    There are a lot of little tricks you can do on the newer (and some older) Fords.
    The ones with all the options had more tweaks....
    But good tip none the less Jake.
    I have a car.
    It has a motor.
    It goes fast.
    Can you help me install parts?
    Dec 2003
    SanAntonio
    Buckleing the seat belt seems to work pretty well for me!!!!!!!!!
    85GT FACH1 FINISHED
    in a happy place Weilding the ban-stick proudly TrueBlueVenom's Avatar
    Jun 2003
    San Antonio
    moved. added steps in Jake's post.
    Come chase this ass Regular Member machgsxr's Avatar
    Mar 2007
    San Antonio
    Did it yesterday and it worked.
    I heard it this morning when I got in the car but will have to check it tonight or tomorrow morning to see if it reactivated.
  6. #6
    Feb 2007
    N.E. SA
    and it's the law !!!
    click it or ticket !!!
    I have a car.
    It has a motor.
    It goes fast.
  7. #7
    . Regular Member zosick's Avatar
    Jan 2006
    or just have tinted window's like me
    i usually click it and un click it right away to ignore the problem.
  8. #8
    Dec 2003
    SanAntonio
    Quote Originally Posted by blkstang87 View Post
    Oncoming police offficers can still see you arent wearing it. And if you hit something YOU will KNOW you arent wearing it as well.
    SEAT BELTS save lives trust me I know from Experience.
    85GT FACH1 FINISHED
  9. #9
    Feb 2007
    N.E. SA
    And air bags hitting the face and arms hurts like a MO FO !!
    not that I speak from experience,..... but have seen the aftermath on cars that have come through the shop with deployed air bags....
    seeing a face imprint on the driver air bag and skin and hair from the arms...
    I have a car.
    It has a motor.
    It goes fast.
  10. #10
    Dec 2003
    SanAntonio
    Quote Originally Posted by 96greengt View Post
    Better than a face imprint on the windsheild and it is worse with no seat belt cuz you keep going forward and the air bag is going the oppisite direction....
    Think about it..
    85GT FACH1 FINISHED
  11. #11
    Feb 2007
    N.E. SA
    gotta love inertia...
    I have a car.
    It has a motor.
    It goes fast.
  12. #12
    Not hot.. Regular Member Chili's Avatar
    Sep 2005
    Euless, TX (DFW)
    Instructions were in my owners manual. I turned it off within a couple of days of buying the car (in 04). I always buckle on the road but at the time I might just be moving the car or sitting in it with the engine running. I know to buckle up, I don't need a computer harassing me until I do so.
    2004 Torch Red GT
    Best 1/8 8.61 @ 81.59
  13. #13
    The Silver Six Regular Member Beck's Avatar
    Mar 2007
    New Braunfels, Texas
    I like this deal.. if I'm sitting in the parking lot durring school or waiting on my girlfriend... Its not all that comfortable to sit with a freakin belt on.. this is nice cause then I dont have to buckle it behind me just to lose that stupid sound.. haha
    +1 thanks!
  14. #14
    LoneStarStangs Addict Regular Member Bulldoser89's Avatar
    Jan 2007
    Grand Prairie, TX
    Seat belt saved my life in 2002 when my friend lost control of his acura @ 90 and hit a pole, it killed him since the pole hit the drivers door. I somehow stumbled away with only scars and a dislocated shoulder......whats wierd is eventho I got out somehow, and the seat belt was buckeled and locked tight...(I have no idea how cause I blackedout and dont remember anything from 1 min before the wreak to about 15-20 mins after the wreak when the paramedics were trying to keep me still......They said I wandered into the road....I guess looking for help. This was in Grand Prairie/Irving cant remember the name of the road tho, right in front of railroad tracks, My friend cross is on the pole we hit.
  15. #15
    Regular Regular Member
    Mar 2006
    San Antonio
    I can't believe I read til almost halfway when I realized you were talking about the chime and not my door dings:eek3:
  16. #16
    Feb 2007
    N.E. SA
    :shthapns:
    I have a car.
    It has a motor.
    It goes fast.
  17. #17
    Jan 2007
    Grand Prairie, TX
    Quote Originally Posted by Razor View Post
    LOL
  18. #18
    95 Cobra fresh fish! TexasDomesticMa's Avatar
    Mar 2007
    Austin, TX
    I did the same thing. I thought it was a joke post for a second.
  19. #19
    i am not a whore Regular Member YZF Voltage's Avatar
    Sep 2006
    San Antonio, TX
    seat belts save lifes... period. wear them. please.
    Quote Originally Posted by semperfimrn1 View Post
    venomm=the new lobra
  20. #20
    Sep 2005
    Euless, TX (DFW)
    This was a good How-to thread that got mucked up by a seat belt debate.
    2004 Torch Red GT
  21. #21
    Mar 2007
    lol :eek3:
  22. #22
    Mar 2007
    Austin, TX
    This didnt work in my 95. Sad.
  23. #23
    Fast "N" Feared Regular Member ForcedInduction's Avatar
    Dec 2005
    lol its a different deal in your 95gt..i alwasy annhilate all the cars i own there dings. Its locted on the drivers side right below where you gas pedal and your obd2 connects is..in the centerconsole. Its a white box. Disconnect it open it up and just take a pair of plyers and rip that black sound device out of it.
  24. #24
    Mar 2007
    San Antonio
    Hahahha. How about an 07 F150? How do you stop that dinging.
