Results 1 to 5 of 5
Thread: distributor wire to the positive or neg side of coil?
    May 2008
    just got a new coil and my old one did not have a positive or negative markings. Does the wire from the distributor go to the positive or negative side of the coil? I tried looking everywhere on the net and could not find a thing.
    Dec 2003
    SanAntonio
    + side is incoming - side is to distributor
    85GT FACH1 FINISHED
    May 2008
    thanks, i took it off and forgot which wires went to what.
    Dec 2007
    Marion
    The wire from the distributor to the coil goes on the negative side of the coil, the positive side of the coil gets power from the ignition switch. When the points are open, the coil is basicaly absorbing electricity, it is nothing more than a capasitor. Once the points close and completes the circuit to ground, the electro magnetic field that builds up when the points were open, collapses and the stored energy travels out the coil wire in the form of a high voltage spark.
    If you don't already know point gap is important, the points need to be clean. They used to make very small files for the purpose of filing the point contact surfaces flat, when they are flat the points work much better. Most single point systems used around .017 point gap, dual points used more like .013 or .014 gap. The larger the gap, the more coil saturation time, also know as dwell or dwell time.
    Dec 2003
    SanAntonio
    Very good laymans explanation sonic
    85GT FACH1 FINISHED
