IT'S A GIRL!! Born: 12-13-07
sounds like u have gears?? if so u need to recal the speedo
yea.. what he said.. if you buy a predator or similar handheld tuner, you can adjust the spedo
#5 | |
You're close enough to Dallas, you can go there (Dallas Mustang?), or if you really want a good tune, go to Oklahoma City; lookup swtuning.com. A dealer wont help you much.
-- Mike -- 2005 V6 Automatic, 300+ RWHP Vortech Supercharger, air-air intercooler, blow-through setup; 42#s; maf.ia; 40mm BOV; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; 3.73s, T-Loc., LPW girdle, alum driveshaft; Steeda panhard bar & brace, CHE lca's; Mac LT headers, high flow cats ![]()
handheld tuner... give john #21 a call hes got one for like 200 i believe.. you'll be able to adjust the spedo cal. with that.
not to mention adjust timing, turn off the 02's and what ever else you want to do when you start adding the mods.
Look in the parts for sale subsection. Thanks for the plug David.
GO SPURS GO
if you are tight on cash
a speedcal from dallas mustang will make the neccessary corrections. You can usually find a used one for only 50 bucks. I highly suggest this over a tuner if money is tight.
