Old 01-24-2008, 12:46 PM   #1
rpalaniz's Avatar
Drag Car #3
Here is a pic of the Newest project to hit the shop, its a wrecked 98 V6 . It will transform into a full gutted, 12 pnt cage, Drag car, we got a replacement clip already, I have bought a 8.8,full weld in sub frames, and alrady have the 4;56's and the engine and trans are already built..C-4 with Cross Boss 302 . It is a 68 302 block with solid cam, and 351 Clevland heads. we did the machine work to the heads in house and made the intake spacers as well, I will get pictures of the engine when I go back home, the engine is on a test stand and has already started up..sounds pretty crazy..oh and it take special pistons for that combo. Im looking for a set of drag springs for the rear, and SSM uppers and lowers.
rpalaniz is offline   Reply With Quote
Old 01-31-2008, 08:29 PM   #2
thesource's Avatar
Trader Rating: (11)
Not bad .....
Old 01-31-2008, 08:55 PM   #3
Sonic Blue 85's Avatar
So what's the rest of the combo piston, rod, crank, intake, CR and which cleveland heads? Was any port work done on them?
85 sonic blue coupe with 302 bored and stroked to 364, Ported Twisted Wedge heads and a BXR intake, A9M ECM with a Tweecer, C4 with trans brake, 275/60/15 M/T drag radials, no power adders.
Old 01-31-2008, 10:34 PM   #4
rpalaniz's Avatar
Combo
It has a Solid 575 lift cam, Custom Pistons that are made for Clevland heads, CR should be arount 10-1 because we dident use the closed chamberd heads, the heads are un ported and have crane roller rockers, and a PP Hurricane INtake..the build kinda focused on the pistons becase a friend had bought them a long time back but did not have the money to build the motor.
Old 01-31-2008, 10:36 PM   #5
rpalaniz's Avatar
stock 302 rotating assemble for now, fixing to tear down and add a forged bottem end along with the rods.
Old 01-31-2008, 11:03 PM   #6
So are they 2v or 4v heads and what size intake valve?
Old 02-01-2008, 12:05 AM   #7
rpalaniz's Avatar
Pretty sure they are 2v..with stock valve size.
Old 02-01-2008, 08:15 AM   #8
I have not heard of anyone building one of these in a long time, years ago I planned on building one. It will be intresting to see what it will do. The few of these I have seen built years ago were just mild street car engines.
