I have a 93hatch and plan to order some drag radials for it. Currently it has 275\60\15's on 15x8 draglites. Should I order 275/50/15's or 275/60/15's?![]()
i have 315/50/17 on mine. i dont know what that would be in a 15
what is your gear ratio? then decide of how tall of a tire you want.
Tuned By Lethal Performance
Support Your Favorite LSS Forum Here!
http://www.lonestarstangs.com/forum/...ber-20351.html
What gear ratio you running out back?
What is your overall combo, how fast is the car, what transmission and rear gear do you have? A 275/50/15 is around 26" to 26.5" tall depends on the wheels you use and exactly what brand of tire you get, the 275/60/15 is around 28" tall that height also varies depending on brand and wheel used. The 275/50/15 is around 11" wide depending on the wheels used, the 275/60/15 is about 9" to 10" wide depending on how wide of a wheel you use. With the 275/50/15 you will need to roll the wheel lips, to prevent them from cutting the tire. With the 275/60/15 you will need to cleance the inner wheel well primarly to the front inner, along with rolling the wheel lips.
Hey thanks guys. I bought a set of 275/50/15's and plan to roll the fenders. How and who does this?
Uploaded with ImageShack.us
2002 MUSTANG GT
CAI,FLOWMASTERS, GUTTED CATS,XPIPE, NITTO DR
FUTURE MOD: ON3 TURBO KIT
2001 MUSTANG V6(SOLD)
CAI, DUAL EXHAUST
