Old 03-16-2004, 02:12 PM   #1
dyno question
Does anyone know if there is a dyno in the Austin/SA/Houston/DFW that can measure boost, a/f? Reason I'm asking is that I'm having 0 luck getting my boost guage to work and I need to know how much boost exactly is getting produced so the guy tuning it can tweak it as need be. Thanks
01 Blk Vortech'd GT 381rwhp and 372rwtq
Cobra Killer S-Trim kit
C&L Plenum w/ FRPP 70mm TB
BBK LT's
MagnaFlow shorty o/r x-pipe
MagnaFlow Catback
Steeda Tri-ax
AJE Tub. K-member and a-arms
MM coilovers
MM LCA's
Steeda HD UCA's
FRPP 3.73's
Custom Subframes
Cobra brake upgrade
17x9 BBS RX
01blkgt is offline   Reply With Quote
Old 03-16-2004, 02:44 PM   #2
PC Load Letter?
99darkgreenGT's Avatar
Send a message via AIM to 99darkgreenGT Send a message via Yahoo to 99darkgreenGT
sup phil.
maybe stop by houston performance next time you are in town.
4VGT | 317.6 RWHP | 312.3 RWTQ | Dyno Sheet | 99darkgreenGT.com
view my web design/commerce sites | BirdDogBowling | BowlingBallAuctions
99darkgreenGT is offline   Reply With Quote
Old 03-16-2004, 02:48 PM   #3
Firemanz's Avatar
www.murillomotorsports.com located here in S.A.
Did you install the guage yourself? Maybe you tapped into something other than a vacuum line?
Lawrence
377.5hp/ 372.9tq@ 8psi
Small vid of blower
<----Click for mods....
Old 03-16-2004, 03:52 PM   #4
yea, installed it and double-checked everything. Its plugged into the red vacuum line coming off of the upper intake which is what I believe is the right line right??? I'm thinking it might be the guage itself or something else I cant think of. So Murillo is able to get boost psi from a dyno?
Sup Chris, when are you going to put the 4v in??? Prob be down there this weekend, but w/o the stang. When's the next HRP day going on for the Houston stangers? Might go down there then.
BBK LT's
MagnaFlow Catback
Steeda Tri-ax
MM coilovers
MM LCA's
Steeda HD UCA's
FRPP 3.73's
Custom Subframes
Cobra brake upgrade
17x9 BBS RX
Old 03-16-2004, 04:24 PM   #5
RaceRat's Avatar
You can measure your boost with Autotap software.
Don't quote me for sure, but I think it's intake manifold pressure minus absolute barometric pressure (approx 14.3) = boost pressure.
03 Sonic Blue Cobra Vert Build #11 - 11.13@125.94 (1.63 60ft, 4015lbs, 17" DR's) Link to Pics & Mods
04 Sonic Blue Lightning 12.9@106 on stock Good Years
RaceRat is offline   Reply With Quote
Old 03-16-2004, 10:42 PM   #6
PC Load Letter?
well i will be graduating in may (finally) and hopefully can get a job to cover a few things. so hopefully sometime this summer. my current priority is upgrading my brakes because they are grinding lol
not sure when i will be heading to hrp, i haven't been in a long time. i am probably very rusty
Old 03-16-2004, 10:44 PM   #7
Firemanz's Avatar
What side of the intake is it on? Mine's on the passg. side and I used a T-fitting for it. When Mike did the dyno, he did't even use my guage, he used one he hooked up himself.
Small vid of blower
Old 03-16-2004, 10:53 PM   #8
RaceRat's Avatar
oops..that was supposed to be a pm. LOL
Old 03-17-2004, 05:19 PM   #9
Here's how I have it connected:
Here arepics in no particular order:
Yellow is where I have it T-d for the gauge
