dyno question
Does anyone know if there is a dyno in the Austin/SA/Houston/DFW that can measure boost, a/f? Reason I'm asking is that I'm having 0 luck getting my boost guage to work and I need to know how much boost exactly is getting produced so the guy tuning it can tweak it as need be. Thanks
01 Blk Vortech'd GT 381rwhp and 372rwtq Cobra Killer S-Trim kit C&L Plenum w/ FRPP 70mm TB BBK LT's MagnaFlow shorty o/r x-pipe MagnaFlow Catback Steeda Tri-ax AJE Tub. K-member and a-arms MM coilovers MM LCA's Steeda HD UCA's FRPP 3.73's Custom Subframes Cobra brake upgrade 17x9 BBS RX |
PC Load Letter?
sup phil.
maybe stop by houston performance next time you are in town.
4VGT | 317.6 RWHP | 312.3 RWTQ | Dyno Sheet | 99darkgreenGT.com ![]() view my web design/commerce sites | BirdDogBowling | BowlingBallAuctions |
www.murillomotorsports.com located here in S.A.
Did you install the guage yourself? Maybe you tapped into something other than a vacuum line? Lawrence
2003 Redfire Roush Stage II #6395 377.5hp/ 372.9tq@ 8psi Small vid of blower ![]() <----Click for mods....
yea, installed it and double-checked everything. Its plugged into the red vacuum line coming off of the upper intake which is what I believe is the right line right??? I'm thinking it might be the guage itself or something else I cant think of. So Murillo is able to get boost psi from a dyno?
Sup Chris, when are you going to put the 4v in??? Prob be down there this weekend, but w/o the stang. When's the next HRP day going on for the Houston stangers? Might go down there then.
You can measure your boost with Autotap software.
Don't quote me for sure, but I think it's intake manifold pressure minus absolute barometric pressure (approx 14.3) = boost pressure.
03 Sonic Blue Cobra Vert Build #11 - 11.13@125.94 (1.63 60ft, 4015lbs, 17" DR's) Link to Pics & Mods 04 Sonic Blue Lightning 12.9@106 on stock Good Years |
PC Load Letter?
not sure when i will be heading to hrp, i haven't been in a long time. i am probably very rusty ![]()
#7 | |
oops..that was supposed to be a pm. LOL
