Old 01-13-2008, 08:56 PM   #1
ken964698
ken964698's Avatar
Electric fan?'s
Are the 94-95 electric fans week compared to the 97-98 fans..seems like my 98 gt fan blows more air than the 95 gt fan...also are they interchangeable? What are my other options for the 95 GT..thanks in advance
ken964698 is offline   Reply With Quote
Old 01-14-2008, 09:28 AM   #2
Jus Workin Away !!!
txlen's Avatar
if ya want alot more airflow swap in a fan off the dodge viper....fits pretty good and moves 4400+cfm....
Old 01-15-2008, 10:02 AM   #3
there are 2 speeds on the 94-95, the high speed scomes on at 208 degrees or when the a/c is switched on.
a few things could happen. your car is not hot enough at idle... a good thing
your high speed has burned out.... happend to mine but it is ok because i have a big aluminum radiator.
you may have had the recal done which actually SCREWED up my fan and the high sopeed would never come on. when I removed their relay it worked again.
if you haev temp problems you can try the high speed manual switch. I believe you tap the purple and black wire on the ccrm( box on the overflow tank) and wire it to a switch which runs to a 12v source. You can check the wire schematic on stangnet in the 94-95 section.
Hope this helps.
