ken964698
Electric fan?'s
Are the 94-95 electric fans week compared to the 97-98 fans..seems like my 98 gt fan blows more air than the 95 gt fan...also are they interchangeable? What are my other options for the 95 GT..thanks in advance
there are 2 speeds on the 94-95, the high speed scomes on at 208 degrees or when the a/c is switched on.
a few things could happen. your car is not hot enough at idle... a good thing your high speed has burned out.... happend to mine but it is ok because i have a big aluminum radiator. you may have had the recal done which actually SCREWED up my fan and the high sopeed would never come on. when I removed their relay it worked again. if you haev temp problems you can try the high speed manual switch. I believe you tap the purple and black wire on the ccrm( box on the overflow tank) and wire it to a switch which runs to a 12v source. You can check the wire schematic on stangnet in the 94-95 section. Hope this helps.
