Old 12-21-2007, 11:50 PM   #1
Emergency help!!!!!
i need to know why the 2005+ v6 mustang procharger kit needs the water pump mount bracket. for some dumb reason the guy i ordered it from as part of a bunch of other parts didnt order it. now im stuck with a torn apart stang and i hit a wall due to this not sure if i really need it. it seems that from what i can tell in the picture its just a piece of metal that you throw on there. some one help please
05madmax is offline   Reply With Quote
Old 12-22-2007, 10:34 AM   #2
anyone know how critical that mount is? if its something i can do without and safely drive the car without it and the procharger on i am about to do the install. it seems that the main bracket is already going to be supported by 3 other points so i am assuming it is not a critical mount
Old 12-22-2007, 03:52 PM   #3
Cool Kid
cmschlatt's Avatar
doesnt seem like it should be necessary. maybe one of our "oh-so-wise" gurus can give you some insight
cmschlatt is offline   Reply With Quote
Old 12-22-2007, 04:58 PM   #4
well according to brian at THR it is possibly one of those that would be best not run boost without. the reason being that it could be one that stablizes the position of the main bracket that holds the blower. without the water pump bracket mount, he said, it might give slack under boost and caus ethe belt to snap or something.
Old 12-24-2007, 01:02 AM   #5
Cool Kid
cmschlatt's Avatar
id play it safe until you know for sure or get the bracket
