Results 1 to 4 of 4
Thread: engine codes
    ! RUMBLE ! Regular Member romizm's Avatar
    Jul 2008
    s.a. town
    engine codes
    i bought a engine code scanner and these are the numbers i got so if anyone can tell me with these numbers relate to let me know these are (koeo)17,28,58,48,18,28,58,41,14,33,14,33
    some nubers came out twice but i ran it again to make sure that i had the right numbers so if anyone can pinpoint the problem with these numbers i'd appreciate it
    Tweecer tune,longtube bbk headers,cutom 3" exhaust x pipe into borla xr 1 racing mufflers,Canfield heads 2.02 1.60,systemax intake system fully ported runners welded for even cfm flow,30lb injectors,highflow 255 fuel pump,,G-Force trans,303 x cam,306 block balanced by t&p,speed pro pistons, Hurst short throw shifter,
    www.myspace.com/rcstangs
    This is my Baaaaaby! What is SilverStar you ask?  Click here to find out! Mustang_68_Coup's Avatar
    Sep 2005
    San Antonio, TX
    1996 GT Vert
    1968 "Vanilla" Coupe
    - Emo Phillips
    Quote Originally Posted by TheSource
    Young girls are hot as shit but usually stupid as a mother fucker.
    Jul 2008
    s.a. town
    i had a buddy of mine come by and he noticed that my 1" spacer that i installed between the upper manifold and spacer it was wet like something is leaking either i have a bad gasket or the spacer might be warped. so i just might have to back to the original spacer and replace the gasket.
    i think i just found my problem.
    Dec 2003
    SanAntonio
    Scanner didnt come with a listing of code meanings?
    85GT FACH1 FINISHED
