engine rebuild
i will be getting a backup shortblock so i can test the roots blower with confidence. later this week i may pick it up and i want to basically play mechanic with it and rebuild it. where is a good how-to site for a rebuild, or can someone guide me?
if i can find heads and intake for cheap or free i'd like to get it in "ready" mode should my stock motor go kaput. i know i need to invest in an inch-lbs tq wrench, but what else? btw it's a '94 v6 shortblock with 80k miles on it. thanks.
littleblackcoupe (9:24:18 PM): I could have brought my coupe out......... littleblackcoupe (9:26:58 PM): just ask tim if it is fast.......... tire26 (9:27:11 PM): why? in case i cared? :-) littleblackcoupe (9:27:34 PM): I doubt you do........ littleblackcoupe (9:27:44 PM): I could give your cousin a ride.......... littleblackcoupe (9:27:50 PM): :-P tire26 (9:28:02 PM): what, a ride that is really fast and over in a couple minutes? littleblackcoupe (9:28:03 PM): lmao littleblackcoupe (9:28:20 PM): that may be you tire26 (9:28:21 PM): jerky, loud, and scary? littleblackcoupe (9:28:28 PM): 2 pump chump........ |
#4 | |
video guru
Re: engine rebuild
you're more than welcome to borrow any tools of mine. i've got an Inch-lbs torque wrench. You might want to invest in the cam sensor tool or talk to brad about the "brad" method of installing it correctly. i've got a Ford shop manual for an 01 Mustang that I "borrowed" from the dealer i worked at. you can borrow that too. |
#5 | ||
Re: Re: engine rebuild
it'd be just too much work, i just need a backup i can drop in and have it driveable asap.Quote:
do i want to know the "brad" method? :Ohreallys -austin |
video guru
Re: Re: Re: engine rebuild
here is my goal:
1) to get it running, and well 2) to improve performance WHERE CONVENIENT (aka where i can do it myself and cheaply) i have: '94: shortblock needing new pistons, rods are good to go, cam good, all of that intact u/l intakes one good head (other one was shitty and threw away) crank pulley, water pump pulley, water pump, harmonic balancer misc. stuff i don't know what it is. should i take the shortblock apart first and have someone look at it and inspect it? what do they measure, warpage of cyl walls, thickness of cyl walls, or what? ps - kyle is my new bestestest friend evar! ![]() |
#8 | |
video guru
a shortblock is more than just looking at the bare block. and even still you can really split hairs looking things over. i'd check for bore taper (make sure the cylinders don't have a slight conical shape) for sure. make sure the crank bore is straight check for cracks. check the deck for warpage then check the crankshaft: make sure it is straight and doesn't have any runout. check the rods to make sure they are straight, etc... i'm sure i'm leaving some things out... |
