Old 08-08-2008, 04:10 PM   #1
engine tapping
I bought a '95 mustang with a 351. The care only has 40,000 miles so the engine has done a lot of sitting. i have had several problems mostly being dry-rotted hoses and gaskets. the other day when i was driving and i downshifted a loud tapping noise started coming from the engine. ive pulled it apart and the push rods look fine. the noise doesnt get louder as i accellerate so i dont thinks it a bearing. the only other thing it might be is a collapsed lifter. i was just wondering if any of yall might have any other ideas?
All show and no go
PrplePpleEater4 is offline   Reply With Quote
Old 08-09-2008, 06:55 PM   #2
Closed for the season
REDHOT86's Avatar
One time my suv was making a taping noise and it turned out my harmonic balancer was falling apart. It made the noise for a few weeks before it finally came apart on me.I had spent a lot of time trying to figure out what it was, then it broke one day while I was driving. These 5.0's are known for balancers breaking and even ruining the engine because of that. I hope that helps. -JM
Mods: 3.73s, Shorties, MAC o/r H pipe, MAC catback, AOD w/shift kit, MAC cold-air, Underdrive Pullies, lowered 1.5" all the way around T5 CONVERSION COMING SOON!!!
Originally Posted by 04Roush2 View Post
All that money and will still sound like a weed whacker
REDHOT86 is offline   Reply With Quote
Old 08-09-2008, 08:39 PM   #3
if you've got the intake off, check the lifters... and/or replace them... you can find lifters (i'm talking about hydraulic rollers) for really cheap... i've got 2-3 sets for less than $100. check that ballancer too. if all of those seem ok, it's time to get a stethescope and see where it's coming from.
1991 lx coupe
Old 08-09-2008, 11:25 PM   #4
CraZy6's Avatar
replace the lifters
CraZy6 is offline   Reply With Quote
Old 08-10-2008, 08:43 AM   #5
If it has done alot of sitting Im betting it is a stuck lifter.
Fire it up withthe v/c's off and see if 1 rocker isnt moving or is loose while it is running.
Old 08-11-2008, 10:33 PM   #6
i thought it was the lifters too, but there was a mild tap coming from them so i replaced all 16, and that wasnt too long ago. Do they require break in time?
myblack93gt is offline   Reply With Quote
Old 08-12-2008, 03:50 PM   #7
91mustang5.0j
91mustang5.0j's Avatar
Send a message via AIM to 91mustang5.0j
Originally Posted by CraZy6 View Post
replace the lifters
x2 i had that preoblem in my 91 replace the lifters an fixed the problem
91mustang5.0j is offline   Reply With Quote
