drewskie68
engine too strong
so i was talking to a guy in one of my classes up at school the other day, and we started talking about cars and junk, and he mentioned to me that ford made an engine for like NRA or something but it was too powerful and they were disqualified. he told me the name was the 427 sideoiler. just wondering if yall had anything else to add on to this because i found that real interesting.
NEED ANOTHER STANG!
i think they just made the oil passages bigger for better cooling and mechanical valve tappets. basically it was NASCAR's crack
2001 Oxford White Mustang GT
True.
" The SOHC 427 represents the ultimate development of the FE engine. By eliminating the rpm barrier of pushrods and lifters, the engine could run easily at 8100rpm and hit 9000rpm for short periods. The hp curve was practically a straight line up to 7000rpm, and in an 8V version reached 700hp. A dual overhead cam version was planned, but never developed, as NASCAR once again squelched this ultra high performance gem from Ford." 427 SIDE OILER |
Box Foxes Rule!!!
A side oiler is not always a SOHC,
but a SOHC is a side oiler. The SOHC had cams in the cylinder heads like the 4.6-5.4 Look at the difference in the cylinder heads on the Mustang and the dragster vid I post. SOHC Mustang 427 SIDE OILER This will help, 427 SOHC -- The Ford V-8 Engine Workshop
Check ya later!
The 427 SOHC was the first engine to break the 200 mph barrier in the 1/4 mile. Awesome engine. It was outlawed in NASCAR which it was originally developed for. Ford ended up using the 427 Tunnel Port which was no slouch either.
and if you find a side oiler block somewhere, let me know as they go for 3k+.
littleblackcoupe (9:24:18 PM): I could have brought my coupe out......... littleblackcoupe (9:26:58 PM): just ask tim if it is fast.......... tire26 (9:27:11 PM): why? in case i cared? :-) littleblackcoupe (9:27:34 PM): I doubt you do........ littleblackcoupe (9:27:44 PM): I could give your cousin a ride.......... littleblackcoupe (9:27:50 PM): :-P tire26 (9:28:02 PM): what, a ride that is really fast and over in a couple minutes? littleblackcoupe (9:28:03 PM): lmao littleblackcoupe (9:28:20 PM): that may be you tire26 (9:28:21 PM): jerky, loud, and scary? littleblackcoupe (9:28:28 PM): 2 pump chump........ |
The tunnel ports did not last long because they had a problem cracking heads. That's one of the reasons for built the 429s and 460s, they needed an engine that was competive with the Hemi, cheeper to build than the tunnel ports, SOHCs and more durable. The 427 SOHC's were rated at 625 hp with two Holley four barrel engines from the factory. Ford was suppose to install them in the 64 Galaxie but stopped when NASCAR banned them. You could order them from any Ford dealer, but they cost more than a 427 Galaxie. It's been a long time since I read the stories on this engine but, I think the 427 Galaxie was like $3800 new and the 427 SOHC was like $7000 new in the crate. Complete with pan, distributor, wires, intake,carbs and exhaust manifolds designed to fit the Galaxie. I had a friend that was an FE nut, who found a SOHC many years ago that had never been run that was suppose to be one of AJ Foyts back up engines, the guy that had it wanted $25000.I would love to get my hands of a SOHC, then bore, stroke it, custom cams, mild port work and them put it in a '69 Mach with a TKO behind it, convert it to port fuel injection.
The goal is to get the car to run 10.0 on radials,with out a power adder and still be streetable. My car is an '85 sonic blue coupe with 302 bored and stroked to 364, Ported Twisted Wedge heads and a BXR intake, A9M ECM with a Tweecer, C4 with trans brake, 275/60/15 M/T drag radials, no power adders. Last edited by Sonic Blue 85; 12-16-2007 at 09:07 PM. |
