exhaust problem?
i have a slight problem!!! i have long tube 3" collectors and bought a mac prochamber but its only 2 1/2" inlet and outlets. anyway i can make it work for the install? looking to get it in soon to complete the exhaust so anything helps. thanks!
#2 | |
Don't hate!
Flare out the inlets for the mid pipe, any exhaust shop can modify that easily. May have to replace the flanges though for 3 inch collectors.
#4 | |
Don't hate!
Should be less then 40 bucks to do, or at least that what I would have charged when I still had the hook up. The flanges would be a few extra bucks.
4 valve FTW
yeah you're probably looking at 40-60 bucks.... tripple A in garland charged me $40 to do a similiar "flare" job when I added some 3.5" tips
SLP loud mouth cat-back, Pro 5.0 short throw, 4.30's, Moser 31 spline axles, Eaton carrier, Steeda sport springs, chrome 18x9 18x10 Saleens, NT555's 285/40/18 rear, MAC O/R Hpipe, RAM power grip dual friction..... ![]() ![]() |
#7 | |
Don't hate!
Long tubes install from me are between 6-8 hours depending on design. Average price is between 500-600 bucks from most shops, prochamber should be included due to having to remove the mid pipe anyway. I always drop the k-member for ease of the install.
