Old 11-16-2007, 11:30 AM   #21
you would get a similar sound with a magnapack axle back oor the ford racing one which is almost identical.
Old 11-16-2007, 12:53 PM   #22
Nice Hat SUfanINsa (Steve)
Agent Jones's Avatar
is magnapack chambered or straight through. i have heard mangaflows on about 3 05+, which i believe are straight threw, and they sound almost stock. I had the borla/ford racing stringers a couple months ago and didnt like them. bought them from a guy off of here.
OU > UT > TT
Old 11-16-2007, 02:04 PM   #23
Guns are cool! Lets kill someone YAY
TheDan's Avatar
I have bassani axle back, the only mod I have and I dyno'd 275
Signature? I dont need no stinkin signature!
TheDan is offline   Reply With Quote
Old 11-19-2007, 09:01 AM   #24
magnaflow makes both of course. Magnaflow is a normal shaped muffler. The tube inside is a straight through and has alot of acking material around it which absorbs sound at idle. Yes it will sound closer to stock and hide things like cam chop. It will get alot louder the moment you stab it though.
Magnapacks are also straight through and the muffler is a larger packed cylinder around the tube that goes inside it. This is average at idle and loud at WOT
if you didnt like stingers, you wont like magnapacks
I think you should try bassani!
Old 11-19-2007, 09:25 AM   #25
i was talking to a guy that's been doing exhaust work for 35 years full time now, he said that until you get into the 5-600 hp range, which aftermarket muffler you chose will make MINIMAL difference... better than stock, yes, but that's abotu it...the highest deciding factor should be which sound you like the best
1991 lx coupe
