Old 06-11-2008, 01:08 PM   #1
SpeedyBolt's Avatar
Fende AMP & Cabinet, WAH pedal, Recording equipment
I am selling my half stack guitar amp. This thing is so bad ass but with the baby now, I had to give up my recording room for a nursery and dont have the room for it any more. So here goes;
FENDER PROSONIC HEAD, Here are some specs on it; 625obo
Year:
1995-Present
Model:
Prosonic Head
Prosonic/Tone Master Enclosure
Circuit:
Config:
Piggy-back
Control Panel:
Black, forward facing w/ white screened labels, controls numbered 1-10
Front Conrol Layout:
In, In, Channel Sw, Vol, Gain 1, Gain 2, Treb, Bass, Mid, Master - Pilot Lamp
Rear Conrol Layout:
Rectifier Sw, Power Sw, Standby Sw, Speaker Jack, Footswitch
Knobs:
Black pointer
Head:
9" x 24" x 9½" (22.9 x 61 x 24.1 cm)
Head Hardware:
Black strap handle or black leather handle w/ footman loops, chassis straps, corner protectors, glides
Cabinet:
27¾" x 27¼" x 13" (70.5 x 69.2 x 33 cm)
Cab Hardware:
2 Recessed side handles, corner protectors, removeable casters
Cab Covering:
Snakeskin, Red, Sea-foam green lizard skin, and black Tolex
Grille:
Silver sparkle or black grille cloth
Logo:
Grille mounted, flat, chrome & black script "Fender" w/ tail
Weight:
Head: 35 lbs. (15.9 Kg)
Cab: 88 lbs. (39.9 Kg)
Speakers/Load:
Combo: 4 x 12"/16 ohms (16 ohms each in series-parallel)
Speaker Model:
Celestion Vintage 30
Effects:
Channel Switching
Output:
SS Rect/AB: 60 Watts
Tube Rect/AB: 50 Watts
Tube Rect/A: 30 Watts
Preamp:
Power:
2 x 6L6
Bias:
Fixed Bias
Rectifier:
Class A/Tube, Class AB/Tube, Class AB/Solid State (switchable)
Phase Inverter:
Comments:
The Prosonic includes a switch for changing the operation class of the amplifier. (see Rectifier)
(NOTE: I do not have the switch to change it but they are cheap)
FENDER TONEMASTER 4X12 CABINET 425.00
I cant find ll the specs on it but I know it had 4 Celsetion vintage 30's in it. I will keep looking for the specs on it
TASCAM 488 8 TRACK RECORDER 125.00
The TASCAM 488 MkII is an eight-track ordinary-cassette-based "studio-in-a-box", with integral mixer section, computer-controlled tape transport, and lots more. Don't confuse it with anything having to do with the old 8-track tapes that people used to put in their cars in the 1970s...this is a sophisticated piece of equipment (see photo), but easy enough for beginners to use, after a bit of practice. Because of the recent introduction of digital multitracks, the street price of the 488 has dropped to less than $800.
STEVE VAI CONTOUR WAH PEDAL 75.00
Morley, makers of pedals and switches, has teamed up once again with Steve Vai to produce a new generation of wah pedals. The Bad Horsie 2 Contour wah was designed for players who like the Bad Horsie sound but want the ability to change the wah frequency. The CONTOUR control adjusts the wah from low bassy moans to piercing high squeals and anywhere in between. It also comes equipped with a wah LEVEL control to adjust the output level of the wah mode. The Bad Horsie 2 Contour Wah also has a special "Clear-Tone" buffer circuitry to prevent signal loading and to drive long cables.
Like the Bad Horsie, the Bad Horsie 2 Contour wah is switchless. The wah switching and sweep are controlled via Morley's Electro-Optical circuitry. No mechanical pot or switch means long lasting wah wah wailing.
email me speeddemon1995@yahoo.com
www.mustangtrends.com
SpeedyBolt is offline   Reply With Quote
