Im selling my new in the box fjo racing products progressive nitrous controller.This one retails for $299 ill take $175 shipped email for pics part # is kws0022 comes with software,cables,and instructions new in the box.2 independent channels
Programmable ramp times (0.1 - 10.0 sec)
Programmable delay times (0.1 - 10.0 sec)
RPM or Time based linear ramp or multi-point curve
Integrated wide-open-throttle detection
1st gear lock-out
Works with rising or falling TPS signals
Supports low voltage tach signals as low as 3 volts
Works with irregular tach signals such as V10 and 3cyl
Easy to use graphic set-up menus using PC USB
Inputs for manual enable/disable or transmission brake, throttle position, tach signal
Integrated LEDs for WOT, stage 1 RPM window, stage 2 RPM window
High current solenoid driver with 40 amp load capacity (continuous duty)
Benefits
