mine are pretty bad, mostly missing in the front.
But I am planning to try to do it myself. Though my welding skills are none. The sheet metal is quite cheap, and I think I can borrow a wire welder. If I ruin the new metal, then I might take it. Plus it is the floor, most won't see it, as long as it is solid. Anyway, planning to get started soon, I have a 65 Coupe, 289 auto. dream of 427 Windsor/6 speed, but that is much later, too much other stuff to do. Rust has really attacked it, may not actually be worth the repair, but it is my first car, owned it for 17 years, and don't want to get rid of her. |
don't know but if you plan to do it yourself go to cal-stang.com the parts has a low price
1993 teal metalic cobra clone-----SOLD 1993 GMC Yukon 2 door 4x4 1965 coupe being built pics will be up soon |
if you were in san antonio we could easily tig in new floor pans for you however in dallas im not sure who
prety much any competent shop with acess to a welder can do it.
Pretty easy DIY job I did my old 65 yrs ago. All you really need is acess to a welder amd or someone to do the weldingg if you are not able to DIY (weld)
how much do you charge for this? If I by the parts? can you replace the rear frame rails for the leaf springs I can do the rest
