Old 04-28-2007, 03:33 PM   #1
Floor pan replacement???
Hi--new to the forum and finally bought a 66 coupe. Does anyone know a place in the Dallas area that will replace floor pans?
bigbubbatex is offline   Reply With Quote
Old 05-06-2007, 02:43 PM   #2
keg65's Avatar
mine are pretty bad, mostly missing in the front.
But I am planning to try to do it myself. Though my welding skills are none. The sheet metal is quite cheap, and I think I can borrow a wire welder.
If I ruin the new metal, then I might take it. Plus it is the floor, most won't see it, as long as it is solid.
Anyway, planning to get started soon, I have a 65 Coupe, 289 auto. dream of 427 Windsor/6 speed, but that is much later, too much other stuff to do.
Rust has really attacked it, may not actually be worth the repair, but it is my first car, owned it for 17 years, and don't want to get rid of her.
Old 05-27-2007, 10:51 AM   #3
fastcat1's Avatar
don't know but if you plan to do it yourself go to cal-stang.com the parts has a low price
1993 teal metalic cobra clone-----SOLD
1993 GMC Yukon 2 door 4x4
1965 coupe being built pics will be up soon
fastcat1 is offline   Reply With Quote
Old 05-27-2007, 09:17 PM   #4
if you were in san antonio we could easily tig in new floor pans for you however in dallas im not sure who
prety much any competent shop with acess to a welder can do it.
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 05-28-2007, 07:19 PM   #5
Pretty easy DIY job I did my old 65 yrs ago. All you really need is acess to a welder amd or someone to do the weldingg if you are not able to DIY (weld)
Old 05-29-2007, 10:56 AM   #6
fastcat1's Avatar
how much do you charge for this? If I by the parts? can you replace the rear frame rails for the leaf springs I can do the rest
Old 05-30-2007, 11:58 PM   #7
keg65's Avatar
most any body shop could do it
