Fluids, Capacities, Tune-Up and Specs
86-93
Recommended Fluids and Capacities Engine Oil : API-SG All except 4 cylinder turbo – 5 Quarts w/ Filter change 4 cylinder turbo – 5.5 Quarts w/ Filter change Transmission Fluids and Capacities T-5: Mercon Dextron III ATF 5.6 Pints AOD: Mercon Dextron III ATF Differential: 7.5” 75w-90w gear oil 3.25 Pints 8.8” 75w-90w gear oil 3.75 Pints **Axles with Traction Lock add 4 oz. of friction modifier when gear oil is changed** Cooling System: 86 thru 87: 4 Cylinder M/T – 9.2 Quarts 4 Cylinder A/T – 9.4 Quarts 3.8 – 10.9 Quarts 5.0 – 13.3 Quarts 1988: Four Cylinder – 9.9 Quarts 5.0 – 14.1 Quarts 89-93: Four Cylinder M/T – 9.7 Quarts Four Cylinder A/T – 10.0 Quarts 5.0 – 14.1 Quarts Power Steering Fluid Type – Mercon Dextron III ATF Brake Fluid Type – DOT 3 heavy duty brake fluid Tune Up and Specifications 2.3 Liter 4 Cylinder Cylinder numbers (front to rear) – 1-2-3-4 Firing Order – 1-3-4-2 Distributor Rotation – Clockwise Spark plug type and gap – Motorcraft AWSF42C or equivalent @ 0.044” 3.8 Liter V6 Cylinder numbers (front to rear) Left side – 4-5-6 Right Side – 1-2-3 Firing Order – 1-4-2-5-3-6 Distributor Rotation – Counter Clockwise Spark plug type and gap – Motorcraft AWSF54C or equivalent @ 0.054” 5.0 Liter V8 Cylinder Numbers (front to rear) Left Side – 5-6-7-8 Right Side – 1-2-3-4 Firing Order – 1-3-7-2-6-5-4-8 Distributor Rotation – Counter clockwise Spark plug type and gap – Motorcraft ASF42C or equivalent @ 0.054” 94-95 Recommended Fluids and Capacities Engine Oil : API-SG 3.8 and 5.0 Liter V8 – 5 Quarts with filter change Transmission Fluids and Capacities T-5: Mercon Dextron III ATF 5.6 Pints AODE Mercon Dextron III ATF 12.5 Quarts Differential: 7.5” 75w-90w gear oil 3.25 Pints 8.8” 75w-90w gear oil 3.75 Pints **Axles with Traction Lock add 4 oz. of friction modifier when gear oil is changed** Cooling System: V6 Models – 11.8 Quarts V8 Models – 14.1 Quarts Power Steering Fluid Type – Mercon Dextron III ATF Brake Fluid Type – DOT 3 heavy duty brake fluid Tune Up and Specifications 5.0 Liter V8 Cylinder Numbers (front to rear) Left Side – 5-6-7-8 Right Side – 1-2-3-4 Firing Order – 1-3-7-2-6-5-4-8 Spark plug type and gap – Motorcraft ASF42C or equivalent @ 0.052” 3.8 Liter V6 Cylinder numbers (front to rear) Left side – 4-5-6 Right Side – 1-2-3 Firing Order – 1-4-2-5-3-6 Spark plug type and gap – Motorcraft AWSF44PP or equivalent @ 0.052” ****More information will be added.****
![]() 1988 Mustang LX |
Daniel You rockstar you
