Old 02-14-2007, 01:00 AM   #1
tire's Avatar
fog light tested, then stops working
i tested both bulbs before installing and they worked fine. once installed into the fog lamp, the right bulb doesn't light. i rechecked the connection, and tested the bulb on the other side, and the bulb itself is good. the right side just isn't getting power. i'm thinking i might have blown a fuse. i found the fog light fuse and it was fine. however, it's dark outside and i can't be 100% sure i checked the right one. is there anything obvious jumping out at you? i leave tomorrow for two weeks on "the high seas", but i'll recheck the fuse when i return.
austin
Old 02-14-2007, 11:25 AM   #2
VIC
The "Senior" Member
VIC's Avatar
Send a message via AIM to VIC
Originally Posted by tire View Post
the right side just isn't getting power. is there anything obvious jumping out at you?
austin
Yes... the right bulb socket is not getting power.
The fuse is good as the left bulb is working. Not seperate fuses for the fogs.
The wiring goes into the right side and then back out and onto the left side.
Check the wiring that runs from the right fog to the left fog light.
