Old 07-10-2007, 02:20 AM   #1
FOG LIGHTS NOT WORKING!!!!!
I have a 02 GT, and my fog lights do not work. I checked the bulbs and they were good. The swith inside works and says the fog lights are on, but they really aren't. Anyone out there have an idea on what the problem can be?
txfight07 is offline   Reply With Quote
Old 07-10-2007, 09:24 AM   #2
Fuse
Old 07-10-2007, 11:13 AM   #3
or relay.. end of story... unless the wires are cut between the switch and the lights
1991 lx coupe
Old 07-10-2007, 04:10 PM   #4
Where is the relay on my car?
Old 07-10-2007, 09:05 PM   #5
You will never get this
Magnapack97's Avatar
Did you try fuse?
Old 07-10-2007, 10:49 PM   #6
LOL @ your mom
Trader Rating: (21)
Relay is here.....
and if the fuse is good, your head lights are on the same circuit.
Old 07-11-2007, 12:43 AM   #7
Originally Posted by Magnapack97 View Post
Did you try fuse?
The fuse was good?
Old 07-11-2007, 12:43 AM   #8
Relay is here.....
http://img224.imageshack.us/img224/9614/relaycs5.gif
The fuse was good.
Old 07-11-2007, 12:48 AM   #9
keg65's Avatar
work backwards from the lights, getting power to the plug, power to the relay, power to the fuse, power to the switch, power out of the switch
1 of 472
Old 07-11-2007, 09:51 AM   #10
LOL @ your mom
Trader Rating: (21)
This may sound stupid................ but is your high beams stuck in the on position? Pull the MFS back toward you and see.....
Old 07-11-2007, 12:50 PM   #11
Nah high beems are good.
Old 07-11-2007, 02:53 PM   #12
excuse me while i go change the water in your mothers dish
YZF Voltage's Avatar
Send a message via ICQ to YZF Voltage Send a message via AIM to YZF Voltage Send a message via MSN to YZF Voltage Send a message via Yahoo to YZF Voltage
bulbs maybe?
Originally Posted by SLOFOX
don't hate the hate, embrace it and enjoy
Originally Posted by BigJnSA View Post
*timpryor* HELL YEAH, I SUCK TOES! *timpryor*
YZF Voltage is offline   Reply With Quote
Old 07-11-2007, 04:40 PM   #13
Originally Posted by VoltageReturns View Post
bulbs maybe?
Bulbs are good also,
Old 07-11-2007, 04:43 PM   #14
Well you need to trace the entire circut starting from the battery and make sure power is going where it should. If all the obvious things are OK it is time to do a little digging and see whats up. For some reason the power isnt getting to the bulbs or switch or relay. Good luck elec traces are a bitch sometimes
Old 07-11-2007, 05:37 PM   #15
Mustang_68_Coup's Avatar
Send a message via Yahoo to Mustang_68_Coup
Do you need to borrow a volt-meter?
It's easy to check ... flip the switch to turn your fog lights ON, go out there and stuff the volt meter in the light socket -- and see if it's registering any power at the plug ....
If NOT, then start tracking it backwards ....
There are only a couple components that make it work:
Bulb
Wire
Fuse
Relay
Switch
One of them has to be the broken piece.
We human beings are very funny: when something bad happens in our lives we say, "Why me? Why is this happening to me?" But when we wake up every morning and are alive and healthy and our family is well, we never say, "Why me? Why am I so fortunate?"
'Life isn't about how to survive the storm, but how to dance in the rain.'
Mustang_68_Coup is offline   Reply With Quote
Old 07-11-2007, 10:16 PM   #16
LOL @ your mom
Trader Rating: (21)
So just how did you test the relay then... swap it with a known good one.
test light to the fog light socket and ground... check for 12v with the switch on.
Old 07-15-2007, 03:11 PM   #17
keg65's Avatar
did you get it?
1 of 472
