Old 08-02-2007, 07:57 PM   #1
divad82's Avatar
FRD-04 AUX Install!
Does anyone have the frd-04 aux installed in there vehicle? I just received mine today but wanted to make sure I do it right. Where do you plug the 12v constant wire? Any info will help. Thanks!
David
divad82 is offline   Reply With Quote
Old 08-02-2007, 08:21 PM   #2
u just need the constant wire? it should be the wire behind your radio that's light green w/ a purple stripe.. anymore you need to know?
Old 08-06-2007, 02:02 AM   #3
divad82's Avatar
Dead Battery
Hey David I hooked the 12v constant where you told me and for some reason it killed my battery. I plugged it into the lighter wire like I believe you mention. Is there anywhere else to hook it up. Wonder why that happened. Let me know the next move. Thanks
David
Old 08-12-2007, 02:34 PM   #4
Novi 22
egomez24's Avatar
I have that on my car and I used the wiring schematic off of thier web site I cant remember what the color wire it was but I know it is a constant fire to the radio itself mine works perfect so I know I installed it right. I will see if I can find the link. if you need to talk call me 210-667-3791 Emilio.
06 Roush
Novi 2k
ARH LT
ARH Catted Xpipe
Magnaflows
355 Gears
492rwhp/420rwtq
