Results 1 to 3 of 3
Thread: front 5lug swap for saleen wheels?
    LoneStarStangs Addict Regular Member coats04's Avatar
    Nov 2005
    smithville
    will they work on the rotor swap or is the 94/95 a must?
    RON PAUL '08
    DEBRA MEDINA '10
    LoneStarStangs Addict Regular Member KO pony's Avatar
    Mar 2007
    San Antonio
    saleens had the same rotors as the SVOs so i would think they would fit. From what ive read if you do the SVO/Lincoln rotor swap you cant fit 97+ OEM rims and bullitts
    GT-40 heads
    Explorer intake
    65mm tb
    Underdrive pullies
    Equal length shorties, h-pipe, and flows
    Pro 5.0 shifter
    Ford Racing "C" springs
    3.90s
    Waiting to put on:
    1.7 rrs
    190lph walbro
    adj fpr
    Oct 2006
    Denton
    I know you can use 03 cobra wheels without centercaps but they kinda look silly. I always suggest sn95 spindles, the 96-98 spindles work great on 91+ cars with the wider fenders, and they're much cheaper than the 94-95 spindles
