FS/FT FULLY BUILT SUPERCHARGED COUPE!!!
Ok I am just going to give you a short run down of this car.. It is a 91 mustang coupe Custom painted camealion, NEW PARTS LIST!!!!
Vortech S-TRIM supercharger with MAYBE 4-5 hours run time. Motor and trans has MAYBE 1000 miles on them. Keith craft Race preped 331 stroker (Balanced) Probe pistons Scat I beam rods and Scat crank TFS cam ALL ARP fasteners ARP head studs AFR 185 heads (with Comp cams valve springs) 1.6 RR Hardened push rods POLISHED Holly System MAX intake 80mm Race T-body 75mm EGR spacer Ford racing aluminum valve covers Ron davis Aluminum radeator Electric fan FUEL SYSTEM Wilbro 255 intank pump Steel braded fuel line #42 injectors adj fuel pressure reg. chrome ProM mass air meter EXHAUST BBK long tubes 3 inch H-pipe 2 chamber flows dumped TRANS. FULLY built bullit proof ART CARR Roller C4 Reverse manual valvebody Trans brake 4000-5500 9 inch stall(still good for the street) Large trans cooler Deep aluminum pan SUSPENTION Qa1 Tubuler K member & control arms Adj. Coil over 90/10 lakewood struts Weld in sub frame connectors 355 gears MAC upper and lower rear control arms Torque box renforcemeants WHEELS & TIRES Weld drag lights 3 1/2 in front 8 in back NEW TIRES The NEW MT drag radeals on the back IGNITION Vortech BTM box MSD 6AL box AWSOME CAR!!! Just lost interest in it. Make the offers Good... There is TONS of stuff I am forgetting, NO SHORT CUTS TAKEN!!! MAKE OFFERS!! TRADES, CASH, CASH + TRADES?? For a QUICK SELL $8500 obo.. Last edited by extremestang; 12-06-2005 at 01:22 PM. |
