#1 | |
FS Strange Ford Drag Brakes
For Sale
Ford 5-lug Strange Brakes part #4145wc. These have been mounted but have never been ran. They include the spindles already modified for them to work. Original buyer backed out ...then i decided to keep them but it looks like I might not have a use for them at the moment.$600 ![]() ![]() ![]()
"it's just a 302" Quote:
LoneStarStangs Addict
awesome set up...bump!
95 Cobra Stock 5.0 motor- MSD 6AL, MSD TFI Coil, MSD Wires, C&L Cold Air and MAF, BBK Long Tubes, UPR X PIPE, Borla Dumps, 3.73s, Hotchkis LCA, Granitelli Adj UCA, Lakewood 50/50 Rear - 70/30 Front, Eibach Drag Springs with airbag, Yukon Alloy Axles, Alum Driveshaft, Edelbrock EFI Nitrous with digital window switch, purge, and warmer, Full Length Subframe connectors, UPR Smog Delete, MMR Rear Seat Delete - looks box stock and best run so far is 12.43 @ 109.86 mph on M/T 26x10 slicks
+1... What K-Memeber and A arm setup are you using?
What size rotor is it and would the spindles work on my '94 GT with stock control arms? Looks like a 4 piston caliper... is that right? Also, does the hub have a stock bolt pattern for the wheels?
Modz Update!!! WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
#5 | |
UPR k-member, v8 spindles and yes the spindles would work on your control arms dont see why not?? You can call strange and refer them the part #
Are the spindles made by Strange also?
