#22 | |
Dumb and dumber
I looked, but I no longer have them. But, you can buy the connector ends from Full Service (not sure on the prices) or, buy the adapters.
#23 |
4 valve FTW
just wondering is programing necessary in order to run the 24# injectors..??
SLP loud mouth cat-back, Pro 5.0 short throw, 4.30 gears, Steeda sport springs, chrome 18x9 18x10 Saleens, NT555's 285/40/18 rear, and an O/R X and RAM clutch soon to come..... ![]()
#25 | |
Dumb and dumber
Yes, cuz they will pump more gas and you need to tune for larger injectors, otherwise, you'll waste gas, and with prices now, you'll see it for sure.
