#22 | |
Don't hate!
I looked, but I no longer have them. But, you can buy the connector ends from Full Service (not sure on the prices) or, buy the adapters.
#23 |
4 valve FTW
just wondering is programing necessary in order to run the 24# injectors..??
SLP loud mouth cat-back, Pro 5.0 short throw, 4.30's, Moser 31 spline axles, Eaton carrier, Steeda sport springs, chrome 18x9 18x10 Saleens, NT555's 285/40/18 rear, MAC O/R Hpipe, RAM power grip dual friction..... ![]() ![]() |
#25 | |
Don't hate!
Yes, cuz they will pump more gas and you need to tune for larger injectors, otherwise, you'll waste gas, and with prices now, you'll see it for sure.
