Old 05-04-2007, 01:37 AM   #1
Harmonic Balancer???
What exactly does it do and if my car shakes a bit would that have anything to do with it? Like always... thanks in advanced for the help.
93GTHatchback is offline   Reply With Quote
Old 05-04-2007, 04:53 AM   #2
'87 LX 'n '95 GT
d4rkpri35t's Avatar
Send a message via AIM to d4rkpri35t Send a message via MSN to d4rkpri35t Send a message via Yahoo to d4rkpri35t
a harmonic balancer is connected to the crankshaft to reduce vibration... so yes, it would cause the car to shake.. when my friends harmonic balancer went out it would only shake when idling.. when he revved up it wasn't so bad... they're not THAT hard to install.. took us about 45 minutes to an hour to replace...
95 GT 5.0 w/ some bolt-ons, 2" Drop Eibach Suspension, C/C Plates, 17" Steedas
87 LX 306ci Forged w/ bolt-ons, 4.10's, Built T5, Weld Rodlites, BBK Headers, O/R X, Magnaflow Dumps.
d4rkpri35t is offline   Reply With Quote
Old 05-04-2007, 08:16 AM   #3
Professional Leash Holder
TheBocSez's Avatar
Same here. During idle and low RPM only, the car would shake.
A lot of times, if you open the hood and watch it, you can actually see it wobbling while the car is running, or if you grab the outter ring, you will be able to move it.
Old 05-04-2007, 08:27 AM   #4
On with the show....
Cruehead's Avatar
Yep...I changed mine out a couple of months ago. The car started shaking around 2200RPM. Rent a puller from Autozone. Remove the radiator fan for clearance. R&R the Harmonic Balancer. Should take you about an hour.
Dave
'07 Redfire GT
Flowmasters, Pypes H Pipe w/ Hi-Flow Cats, C&L CAI, SCT X-Cal2 (BamaChips), FRPP 4.10's
Cruehead is offline   Reply With Quote
Old 05-04-2007, 11:22 AM   #5
greenmachine302 is offline   Reply With Quote
Old 05-04-2007, 11:24 AM   #6
"rent a puller"? Will I need that to get the part off? How much is it to rent?
Old 05-04-2007, 11:26 AM   #7
Also will is cause the shifter to shake as well while idleing and a bit while driving?
Old 05-04-2007, 11:40 AM   #8
Cruehead's Avatar
Yeah...autozone has a loaner program. You pay, I think $15 for the puller (to get the harmonic balancer off), and get your $15 back when you return it. You'll definitely need the puller in order to get the HB off.
Yes...it shook my entire drivetrain when mine went bad.
Dave
'07 Redfire GT
Old 05-04-2007, 11:50 AM   #9
Alright then.I guess I have to take mine off this weekend and see if that is my problem. Thanks for all the help everyone.
Old 05-04-2007, 11:59 AM   #10
Cruehead's Avatar
You can get under the car and rub your finger around the face of the balancer. If you feel the rubber bushing protruding out of any part of the balancer, then you know it's bad. It'll save you time just in case it's not the balancer.
Dave
'07 Redfire GT
Old 05-04-2007, 03:55 PM   #11
'87 LX 'n '95 GT
d4rkpri35t's Avatar
Good luck with the replacement.
Old 05-05-2007, 12:26 AM   #12
One more question...
Will all the shaking and everything cause timing/idling problems as well???
Old 05-05-2007, 12:26 AM   #13
Thanks.
Old 05-09-2007, 08:30 PM   #14
LOL @ your mom
Trader Rating: (21)
You could have worn or busted motor mounts too, bad plugs, wires, misfire, vacuum leak... the list goes on...
Do what they mentioned, go under the car, look at the balancer, see if the outer ring has slipped, or the rubber is missing any pieces, or coming out. You can also remove the balancer and start the engine to see if it is gone... if it is still there, you have other problems. If i remember correctly, no oil will come out either. I am not a 5.0 guy, I am more a modular guy, but I remember working on those....
Old 05-09-2007, 08:30 PM   #15
highspeed's Avatar
No... The engine vibration would not have any effect on the timing of a motor.
Old 05-18-2007, 01:17 PM   #16
rpalaniz's Avatar
READ!!!!!
Guys if you replace your Balancer be sure to replace it with a good quality unit, Ive seen cheap china stuff come apart and Ruin a motor. Spend a few extra bucks and get a good one...Thanks
rpalaniz is offline   Reply With Quote
Old 05-22-2007, 12:18 PM   #17
The One and Only...
black95o's Avatar
good lookin out guys...seems mine just went out as well. gotta love them 5.slows, lol
---Looking for '02 and up 600cc sport bike---
pm for details
black95o is offline   Reply With Quote
Old 05-28-2007, 04:51 PM   #18
The One and Only...
black95o's Avatar
what is r&r?
pm for details
Old 05-28-2007, 05:24 PM   #19
LOL @ your mom
Trader Rating: (21)
Originally Posted by black95o View Post
what is r&r?
In automotive terms, R&R mean Remove and Replace.
or even Remove and Re-install
Old 05-30-2007, 12:03 AM   #20
you smell that?!
311-420's Avatar
if you have a spun balancer, your car will most likely run like shit(if thats what you meant about the timing being f'ed up).
04 Mach 1- K&N drop-in, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
