Old 01-11-2008, 10:56 PM   #1
BHAM's Avatar
HARMONIC BALANCER
NEW SFI 18.1 Approved (Fits 302 HO Ford 82-93) Fluid Damper. 6.625" Dia. This damper is manufactured from forged 1025 steel housing and filled with high viscosity silicone fluid. Reduces Rotating Mass for a quicker revving engine. Reduce rotating mass and noise to 2/3's of the original OEM A Fluid Damper absorbs the Torsional Vibration from the Rotating Assembly at All Frequency's and at all RPM's. This significantly Increases the Bearing life! SFI 18.1 tested and approved to 12,500 RPM for Explosion Proof operation. Engraved Timing Marks. This unit can be disassembled for balancing with your rotating assembly!! Check your parts source... these Retail for $359.00!!
100.00 TAKES IT CALL ME 512-573-2883 WILL TRADE TOO
BHAM is offline   Reply With Quote
Old 01-17-2008, 01:50 PM   #2
BHAM's Avatar
bump
