Old 07-09-2007, 02:46 PM   #1
pinkpony_racing's Avatar
HELP!!!!!!!
OK here's the issue my VATS or PATS system will not let me start my car. The other night I was driving to the store, right up the street from my house it just stopped and I couldn't start it. Any idea's of how to bypass this or how to reboot the system. Or if I cant do that any idea's of when I can have it fixed.
Tks in advance for any help......ppr
pinkpony_racing is offline   Reply With Quote
Old 07-09-2007, 03:06 PM   #2
ouch... that's gonna be tricky.. good luck..
Old 07-09-2007, 03:08 PM   #3
Have you tried locking and unlocking again via remote?
I know mine (factory) has a valet button way up under the dash which you press and it will start.
Other wise try pulling the neg batt lead to reset the comp.
Old 07-09-2007, 03:14 PM   #4
I've done all except look for the button how far up the dash are we talking and what does it look like
Old 07-09-2007, 03:24 PM   #5
Mine is kinda hidden deep under above the gas pedal its just a little black push button
Old 07-09-2007, 03:29 PM   #6
Don't hate!
Trader Rating: (20)
If yours is a 96, try to cycle the key about 10 times to 'relearn'.
Otherwise, you will need to get it towed and reprogrammed.
There is NO bypassing the circuit without extensive modifying and multiple resistors inline to do so. And it is called PATS.
Old 07-09-2007, 06:18 PM   #7
tks guys preciate
Old 07-09-2007, 08:06 PM   #8
Something in the PATS system went crappo, prolly the key. If you have a spare transponder key for that car try it. If not you can try banging your key on something hard and it may get you to a dealer. I have been seeing a lot of transponders going bad on the older Fords lately. LUK
Old 07-09-2007, 08:47 PM   #9
Don't hate!
Trader Rating: (20)
Or grab a BFH......
Old 07-09-2007, 09:02 PM   #10
Or grab a BFH......
And call it names....
Old 07-09-2007, 09:52 PM   #11
excuse me while i go change the water in your mothers dish
YZF Voltage's Avatar
Send a message via ICQ to YZF Voltage Send a message via AIM to YZF Voltage Send a message via MSN to YZF Voltage Send a message via Yahoo to YZF Voltage
ouch wow that sucks. maybe punching a wall might help.
PHL 4 LIFE
2003 Yamaha YZF600R - http://www.sanantonioriders.net (SAvoltage)
2004 Chevy Avalanche Z71 - http://www.saoffroad.com (Thrasher86)
Originally Posted by Cartman
It's a man's obligation to stick his boneration in a women's separation;
this sort of penetration will increase the population of the younger generation.
YZF Voltage is offline   Reply With Quote
Old 07-09-2007, 10:06 PM   #12
4 valve FTW
seco's Avatar
o shit..... I still haven't bought a spare key...... damn slacker
Old 07-09-2007, 11:18 PM   #13
thunderchicken's Avatar
Smile
Really should consider it,just to be on the safe side.....
Old 07-10-2007, 12:51 PM   #14
^^^Yeah I would because now Im stuck and I hate having no car. I will try your suggestions though wonder if banging my head will do the trick.....
