Old 10-04-2007, 01:57 AM   #1
sauccarl's Avatar
Help! EGR Engine Code Popping Up!
What is normally the problem when the EGR engine code is popping up? I have the 02 V6. Any help is appreciated! Thanks!
sauccarl is offline   Reply With Quote
Old 10-04-2007, 11:06 PM   #2
l_shizzle_l's Avatar
Well it depends on what it is. I currently have P0401 but i don't have an egr at the time either.
HI!
Forged and stroked 4.3L V6
l_shizzle_l is offline   Reply With Quote
Old 10-12-2007, 08:51 PM   #3
Supercharged
Send a message via AIM to VCS_SSSTANG
Could be clogged (rare)
Could be one of the sensors gone out (very likely)
Whats the code?
1986 Grand National For Sale Clicky!
Less is More
VCS_SSSTANG is offline   Reply With Quote
Old 10-12-2007, 10:56 PM   #4
BigJnSA's Avatar
i wanna say thats usually the DPFE. (grey or black rectangle box w/ a wired plug and 2 rubber hoses)
Originally Posted by thesource View Post
Thats why you don't mess around with that funky cold medina .
BigJnSA is online now   Reply With Quote
Old 10-13-2007, 02:45 AM   #5
sauccarl's Avatar
I decided not to bother with it so I took it to the dealer to get it checked since it's under warranty. Thanks for the help guys!
Old 10-13-2007, 07:24 AM   #6
re re
Trader Rating: (14)
Jason is right, it IS the DPFE sensor. Simple fix/repair and can save you lots of $$$.
I work on cars for a living and spent 8 years with Ford. Since the inception of the OBDII systems, EGR valves on Ford's almost never go bad any more. It is the DPFE that fails.
Originally Posted by ezblonde
Old 10-13-2007, 08:02 AM   #7
BigJnSA's Avatar
*pats myself on back*
thank you, jody, thank you!
Old 10-13-2007, 12:01 PM   #8
sauccarl's Avatar
since I'm a complete noob at domestics what is the DPFE sensor and where is it located?
Old 10-13-2007, 03:28 PM   #9
BigJnSA's Avatar
this pic is the underside. all you see from above is the flat, rectangular shape of the top.
Repeated PFE-DPFE Sensor Code
Old 10-17-2007, 01:41 PM   #10
sauccarl's Avatar
And you were correct, it is the DPFE sensor that went bad cheapest place I found it was for about $50. Where is it located anyways?
Old 10-17-2007, 07:46 PM   #11
re re
Trader Rating: (14)
Who da man ??
It is located on the upper plenum, in the front before the throttle body, it will have an electrical plug with two hoses connected to it.
Old 10-17-2007, 10:07 PM   #12
sauccarl's Avatar
Who da man ??
Kool thanks!
Old 10-18-2007, 07:39 AM   #13
BigJnSA's Avatar
$50 sounds pretty high. ive bought 2 of them before and they were both $20 - $25.... check vatozone.
Old 10-18-2007, 02:12 PM   #14
sauccarl's Avatar
I called Checker, Napa and Vatozone and it's $50 at all three places.
Old 10-18-2007, 08:14 PM   #15
re re
Trader Rating: (14)
The DPFE for your old school cars Jason were cheaper, the newer styles are a tad more money!!
Jason chimed in first, so he is da man !!!
Old 10-18-2007, 08:29 PM   #16
BigJnSA's Avatar
but, hey - i learned it all from jody!
i guess you now know that i drive old POS's!
Old 10-18-2007, 08:35 PM   #17
re re
Trader Rating: (14)
Peggy too ?
