Old 02-01-2007, 01:41 AM   #1
Send a message via Yahoo to gonzie_420
Cool help my o2 senors
my o2 sensors is going off on my 95 v6. i replaced all 4 n da dam check engine still wont turn off . change da egr dat made a difference i dont kno wt else it can b? any one help
gonzie_420 is offline   Reply With Quote
Old 02-01-2007, 04:39 PM   #2
Go to Autozone and have um pull the codes
Did you disconnct the battery? If not try that and leave it off for at least 15 min
Old 02-23-2007, 04:11 PM   #3
LOL @ your mom
Trader Rating: (21)
Autozone sux when it comes to any diagnostics, they always try to sell you an 02 sensor anyway, then they just happen to have that sorry piece of shit Bosch 02 in stock.....
Contact my by PM and I may be able to hook you up.
Old 04-14-2007, 11:26 PM   #4
Bad catalytic converters can also cause O2 sensor codes....
Old 04-14-2007, 11:38 PM   #5
LOL @ your mom
Trader Rating: (21)
Only 2 months late Dan... lol
Old 04-14-2007, 11:58 PM   #6
I figured I was gonna get that. But just incase someone else see's this in the future.
Old 04-16-2007, 07:52 PM   #7
FordGT08's Avatar
Send a message via AIM to FordGT08
i would try the battery...disconnect it
FordGT08 is offline   Reply With Quote
