Old 03-03-2007, 04:18 PM   #1
Cedrich's Avatar
Help with Rear ends
What is the difference between a 7.5 and a 8.8.
Cedrich is offline   Reply With Quote
Old 03-03-2007, 06:33 PM   #2
LOL @ your mom
Trader Rating: (21)
The 7.5 generally found on V-6 mustangs, 7.5 inch ring gear and the 8.8 found on GTs, Explorers, and some F-150s.
Thats the major difference, next is strength., The 8.8 being stronger and called Traction Lock, meaning it has clutches in the differential.
Old 03-03-2007, 06:54 PM   #3
thunderchicken's Avatar
WAS THAT THE HP AFTER YOUR ADD ONS?
Old 03-03-2007, 07:34 PM   #4
LOL @ your mom
Trader Rating: (21)
If you are referring to me, no, that is bone stock with 182k miles on it.
Old 03-03-2007, 09:50 PM   #5
7.5 and 8.8 are the size of the ring gears. Bigger is generally stronger. The 7.5's also came in the older V8 FOX bodies.
