Results 1 to 14 of 14
Thread: HID problem
    Newbie fresh fish!
    Aug 2009
    HID problem
    i ordered a dual beam HID kit for my 2001 Mustang. I hooked everything up and i have a bulb out indicator on my dash. The problem is that with a dual beam kit it only plugs into the factory harness on 1 side, leaving the passenger side factory harness unused. I temporarily fixed the probelm by plugging in a regular 9007 bulb into the unused factory harness, allowing everything to work properly. Im looking for a way to fix this. if anybody has any input it is apprieciated.thanks.
    Apr 2007
    Waco, TX
    Quote Originally Posted by Ron_B View Post
    that doesn't make any sense for it to only plug in on one side of the harness... What kind of kit is this? I have single beam HID's which use regular Halogens for the high beams, and all plugs inline with the factory harness... no elimination of one side. Sounds like it's not connected right...
    And we have a "bulb out" indicator in our cars?!?! I never knew!
    Newbie fresh fish!
    Aug 2009
    Quote Originally Posted by Bigdrumma22 View Post
    im confused on how you can use regular halogens for the high beams but have hid lows?2 bulbs?can u explain please?(im not being saracastic,lol)
    the single beam HIDs use the factory harness on both sides, the dual beam HIDs only use one factory harness (this is my second kit, 2 different brands).this kit is from DDM tuning.
    when the high beam indicator comes on in the dash(without the high beams on), we figured it was a "bulb out" indicator.
    Apr 2007
    Waco, TX
    Well my headlight housings (aftermarket) are setup for two different bulbs on each side. So my low beams are HID's since they're used most often, and my high beams are regular Halogens. The kit I bought was from stangmods.com and everything was plug and play. I still don't get why the dual beam would connect any differently but hopefully someone else with dual beams can chip in...
    BRING ME MY RAPE SHOES! Regular Member BlackSunshine01's Avatar
    Jan 2008
    north east s.a.
    my buddys set up is like this on his f150. i know he said that he only uses one plug and then its distributed through a relay. this dual beam uses one hid bulb that moves up and down correct?
    getting thereh&r ss springs, kyb shocks&struts, 17x9 and 17x10.5 03 cobras, bbk catted x with borla stingers, sct tune and 3.73's.
  6. #6
    Newbie fresh fish!
    Aug 2009
    Quote Originally Posted by BlackSunshine01 View Post
    correct
  7. #7
    Jan 2008
    north east s.a.
    ya thats what i thought. i just asked my buddy and he dosent have a lamp out warning on. so i dont know what to tell ya man
  8. #8
    Newbie fresh fish!
    Aug 2009
    its really stupid because i had the same style kit on my 98 and worked fine, my friend has the same style kit on his 94 an it works fine. but my 01 is being a pain for some reason.
  9. #9
    hmmm... Regular Member ImpactStang's Avatar
    Apr 2004
    San Antonio
    is it the same kit ur supposed to be using? maybe a different kit than what u had before?
    94-98 might have a different setup maybe?
    Quote Originally Posted by AWDFTW View Post
    That's because you are a lean mean zombie fighting machine! If zombies weren't enough to worry about, you have to fight off the all the ladies, because there is just so much of you to go around.
  10. #10
    Drunker than You!! Regular Member einehund's Avatar
    Dec 2007
    Stuttgart, Germany
    i had the exact same problem. I two of the wires in the relay harness were in the wrong slots. i had to pull the wires out and put them in the correct slot in the harness. if i remember right, it was a negative and a ground that were mixed up.
    2002 Mustang Gt 5speed. BBK CAI, PP 75mm TB, RPM upper plenum, Moto blue U/D pullies, X3 handheld, Steeda Tri-ax shifter, Borla Stinger catback and some FRPP 4.10's out back. [email protected]
  11. #11
    Newbie fresh fish!
    Aug 2009
    Quote Originally Posted by einehund View Post
    are you talking about the 3 wires that come on the harness with the hids that plugs into the factory harness?
    where did you order your kit from? min is from DDM tuning.
  12. #12
    Dec 2007
    Stuttgart, Germany
    i got mine from sacramento-mustangs. PM replied to.
  13. #13
    On the hunt Regular Member 89-cobra's Avatar
    Feb 2006
    San Antonio
    yep tht should fix ur prob... i have this kit on my 98..
  14. #14
    03vettekillet fresh fish!
    Mar 2010
    houston, tx
    i installed hids on my 03. i put dual beam hids in the headlights and i also put hids in my fog lights. if it is a true hid kit then it should have come with two small silver boxes(one for each headlight) these are your balists. the balists plug into your stock wiring but you should have gotten one for each side. my fog lights were different, i had to splice into the factory wiring, it didnt just plug right in.
