horn issues
I hooked up the horn today and it just keeps going off , and when I pull on the disc on the steering wheel it stops , but as soon as I let go it goes off again , seems like there should be something to keep it from doing this ,, please help....
Southernstang93 many upgrades |
that was what I was thinking , it makes since but there not one there , is this a part I can get at auto part store????
What year is the car?
You can probably get it in a horn kit for an aftermarket steering wheel, not sure if itt will be available seperately or not
kinda goin' on what don is saying, get an aftermarket wheel and do it that way.. that means ditching the airbag if it's a 93 but it KINDA sounds like you've already done so from reading your first post
t-5 swap, billit quadrant, upr firewall adjuster, steeda tri-ax, custom jb tool and fab one off subframe connectors, 8.8 w/posi and 4.10's with 5 lug axles, tubular upper control arms and southside lowers next, '00 gt brakes, followed by my 306 swap |
I was also. And not meaning to change th entire wheel just pick up the horn kit
it is for a 67 , 93 is gone and in it place is a 67.. I will check in to the after market kit , wish I new the spring size I could track one down
#11 | |
