| 5.0 Tech (79-95) Discuss the 1979-1995 5.0 Mustang |
horse that wont run
i have an 87 gt. i can drive it for 15 min cut it off and it wont start back up. i have went through the electrical and fuel systems. i have spark at my plugs and 40 psi at the rail. i am running a 302 bottom , edelbrock performer 2 intake, performer heads , 1.7 roller rockers, 541 lift comp cam. if you have any input let me know
I would have to bet you have a TFI module that is acting up.
Moving to tech....
![]() 1988 Mustang LX |
I've had that same problem, when it would get warm, the power would drop, then the engine would die. Once everything cooled, then it would start again, but the same.
Checked fuel and spark, everything was good. Turned out to be a cracked distributor cap!! Just a cheap thought
i was gonna say that or the coil... either that or the dist. control module inside the cap... (this is a universal sounding problem so i'm not positive that these cars have that module but i imagine it does)
Professional Leash Holder
well he is the mechanic, so he is probably right
Im not always right, but that is very common on the Ford TFI modules...especially the ones mounted on the distributors.
I always carry a spare TFI module and the tool in the back of my stang just in case.
agrees
ok the thing i was talking about is the tfi module.. didn't know what it's called on these... if i'm not mistaken that's the part that you swap in when youre converting a points dist to an electronic one.. right? that's exactly what i was thinking of... called the hei control module in chevys... still learning abotu the stang stuff
![]() Join Date: Nov 2004
TFI module or maybe the pick up coil inside the distrubtor itself .
I've seen both cause his symptoms. I have always replaced both as a pair when failure has occured.
my bet is the coil try that first typical symptoms
Pull the distributor to make sure the gear is not damaged. I went through the same thing when I put the engine back in my old mustang. The car would run for a while, get hot and shut off. It would take a while to turn on. I ended up replacing that module and coil but the main culprit was that little gear that sets in..
