Old 05-02-2008, 09:31 PM   #1
i wanna go fast
cooper1320's Avatar
Send a message via MSN to cooper1320
how mu HP should i be getting of 351w swap??
just wondering what numbers i could see for my 351w swap that im planing to do, IT's going to be A
351w with
351w professional products intake
Edelbrock Aluminum Cylinder Heads
1.7 rockers
new aftermarket vaules
good cam/ the right cam for this set up
24lb injectors
aftermarket pulleys
255lph fuel pump
28 good HB
80mm match maff
70mm TB
billet or Aluminum flywheel
fuel pressure reg
shorty or long tube aftermarket headers
x-pipe
bullet mufflers
351w after market diss.
mas d 6al
i thinks thats it, does anyone know what RWHP i should be hitting??
thanks
Live Fast Drive A Mustang
cooper1320 is offline   Reply With Quote
Old 05-03-2008, 10:46 PM   #2
Lifted78Chevy's Avatar
400 plus easy
1989 LX Coupe 5.0
HP/335
TQ/362
list goes on forever....she slooowww!!
Old 05-03-2008, 11:40 PM   #3
about 340 rwhp the prof prod intake is restrictive and the edel heads are on the low side for alum heads 340 to 360 rwhp
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 05-04-2008, 08:25 AM   #4
Check ya later!
351w with
1.7 rockers
24lb injectors
aftermarket pulleys
255lph fuel pump
28 good HB
80mm match maff
70mm TB
fuel pressure reg
x-pipe
bullet mufflers
mas d 6al
thanks
I have a complete built 351 w pm me if you are interested.
Old 05-05-2008, 11:37 AM   #5
about 340 rwhp
your combo is very vague and I would go 30 pound injectors, bigger intake and a lot of other changes
IF you had better heads and a really good cam I could see 400 out of it.
some ported trick flows, or a number of other combos will work well. You will need a better intake.
Old 05-05-2008, 11:43 AM   #6
thesource's Avatar
Trader Rating: (11)
Like they say when you use 302 parts , you get 302 power .........
Old 05-05-2008, 08:57 PM   #7
Sonic Blue 85's Avatar
What is a 28 good HB?n That will probably be the thing that determines the final out put.
85 sonic blue coupe with 302 bored and stroked to 364, Ported Twisted Wedge heads and a BXR intake, A9M ECM with a Tweecer, C4 with trans brake, 275/60/15 M/T drag radials, no power adders.
Old 05-05-2008, 09:02 PM   #8
LOL
MIKE
'86 GT:high 12's
Sold
'01 GT:low 11's
for sale
Old 05-05-2008, 10:14 PM   #9
highspeed's Avatar
I thought the "good cam/ the right cam for this set up" was the final output here!!! Lift and duration specs implied!!!
Modz Update!!!
WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
  • MAF support brace - '94 GT
  • Maximum Motorsports Panhard Bar
  • Canton radiator overflow reservoir
  • Fidanza or Spec Billet Steel Flywheel - (50oz 302cid 10.5" 157 tooth)
  • T56 Tranny with 5.0L Bellhousing & support brace
  • Maximum Motorsports Tubular K Member
  • Maximum Motorsports Tubular A Arms (std offset)
  • Coil over struts
Old 05-06-2008, 10:17 AM   #10
e303 should be perfect
Old 05-06-2008, 11:55 AM   #11
yep.....let me restate.......capable of 400 hp...with right combo......but its pretty easy with right parts make 1.14 hp per cu/in. with that motor.....right intake, cam, etc.
if i making 335 at the wheels, means im making 361hp at the fly....335x.08=26.8 hp lose....if u lose 8% hp get it to the ground, so with my 347 is making 1.05 hp cu/in.......my motor not even were it should be to make max hp with heads that are on it......new cam, better intake..etc... so i would differently say 351 can make 400hp.......listen to these guys there getcha there.......:-p
1989 LX Coupe 5.0
HP/335
TQ/362
Old 05-08-2008, 08:36 AM   #12
caleb's Avatar
Send a message via Yahoo to caleb
i agree if your gonas build it build it right this combo is oly good for about 340 maybe 360 hp im buildin a 351 bored .30" over now and the and im not usin any 302 parts except maybe the fuel injection from it or a 351 ruck motor as i dont want a carb
91 gt stock except super 44's x-pipe no cats long tubes and cold air intake, black ponys (awaiting fr500's) and in the process of building a 351 w bored .30" w/ 11 1/2 compressoin on 300 shot
caleb is offline   Reply With Quote
