how much horse power on 01 gt??
I just bought a stock 01 gt and planning to do some mods real soon such as patroit stage 2 heads w/ comp cams, trick flow intake,tb, bbk long tube headers w/ off road x-pipe, bbk c.a.i. ,3.55 gears,center force clutch all at once,and later on a procharger but not yet . what kind of horsepower am im looking at? and if there is any insight or advice ill be glad to listen. Thanks
275-285rwhp prior to the Procharger. With the Procharger and the other mods (heads/cams) you could be around 425rwhp with stock pulley.
#4 | |
If you just want some giddy up for now gears will make you happy for at least a few months.
#5 | |
I'd skip on the heads from Patriot and Comp cams all together. I'd look into getting your heads worked over by a good shop or buy some from Fox Lake. As far as the cams, either get some VT cams or buy forged pistons and get them fly cut with those cams. To get over the 300 hp mark, you'll need more mods then what you have, but with the right combo, you can be over 300 with the mods listed, just different parts...... make sense?
#7 | |
#8 | |
Lets not hijack this thread, I'll shoot you a PM.
#9 | |
i have heard bad things about patriot..... i would go SC then get some Foxlake heads or MPH Heads and some MPH blower cams..
Vtengines went out of business.. Welcome To VT Engines! Last edited by oreo; 12-03-2007 at 06:21 PM. |
#11 | |
