how to replace a heater core on 96 gt
were do I start on replacing the heater core on a 96 GT . I have not did one yet but how do you do this or is there a web site that I can look at ? tony
1993 teal metalic cobra clone-----SOLD 1993 GMC Yukon 2 door 4x4 1965 coupe being built pics will be up soon |
no easy way
NOShit www.sponsorhouse.com/Members/tonir |
#4 | |
What's it gonna be?
I can do my core in under 2 hours... I have gotten good at doing it. My car when I purchased it had the core bypassed, original owner did not want to shell out 6 hours of labor and an additional 130 for the OEM core, so I got a hold of it, bought one from an after market store and have had to replace it once a year due to sorry ass design of the copper cores. Now, I finally broke down and bought an aluminum one and have not had a problem since. Guess it helps the fact that I also do this shit for a living.... working on cars that is for a career...
I just pull the dash back, I do not remove it, only kicker is, to do it right, you have to pull the dash and recover the freon too, but there is always a trick.
