Old 12-01-2003, 05:34 PM   #1
SassyCassy's guy :P
Send a message via Yahoo to jason10mm
how to replace alternator?
Well, it turns out that my alternator IS faulty, and is undercharging the battery (thanks to those who insisted I check it!). With the engine on the machine was reading 13.91-93 (volts?), whcih the guy said was under the bottom limit of 14. Guess it needs replacing, 2 months after my warranty expired
So, how complicated a job is this? It looks like it is just connected by 4 bolts, some wires, and the belt. I was just going to get a new one from Autozone, any particular brand or model? I'm not a racer or a stereo guy, so I don't think I need a different one than what I have now, unless there are obvious advantages. How do you take off the belt? Any tricks to the replacement? I'm planning on just doing it in the parking lot of autozone so I can get it checked afterwards. Thanks.
jason10mm is offline   Reply With Quote
Old 12-01-2003, 05:43 PM   #2
Man law?
Disconnect negative terminal of battery. Use a socket wrench without any sockets. Use it on the belt tensioner. There should be a square hole in it to jam the socket wrench. Remove belt. Disconnect any alternator wiring. Unbolt alternator. Have autozone swap pulley if necessary.
Am I leaving anything out?:party3:
Old 12-01-2003, 06:10 PM   #3
RaceRat's Avatar
Jason...I have a stock 99 alternator. It was on the car for about 10K miles. Had to go with a Cobra alt for the Bullitt intake. $75 if you want it and Todd can help you install. He's done enough of them.
03 Sonic Blue Cobra Vert Build #11 - 11.13@125.94 (1.63 60ft, 4015lbs, 17" DR's) Link to Pics & Mods
04 Sonic Blue Lightning 12.9@106 on stock Good Years
RaceRat is offline   Reply With Quote
Old 12-01-2003, 06:30 PM   #4
GO SPURS GO
LugNutZ's Avatar
Send a message via AIM to LugNutZ
Don't touch the +terminal and any metal part with wrench....
I just did mine on the fox this weekend, seems you got the same steps I followed.
1984 GT
1993 GT
2004 GT R.I.P
2003 F-150 4.6l
2007 GT
LugNutZ is offline   Reply With Quote
Old 12-01-2003, 07:03 PM   #5
95snoozer
Guest
Posts: n/a
that looks just fine to me.... dont let them BS you
and changing your alternator is a POC if you choose to do that
Old 12-01-2003, 08:50 PM   #6
...So I dub thee Unforgiven.
redrum's Avatar
jason, if you plan on getting UD pullies, i would go ahead and get a better alternator at the same time, since its only a few bucks more. i did.
it was a real easy job on the fox, but of course.. fox and 99+ are different. good luck to ya:jeff:
Old 12-01-2003, 08:53 PM   #7
tire's Avatar
i was going to say the same thing as redrum... you can go 50% with a better alt. perhaps, i know some v6 guys can, like talleywhacker.
Old 12-01-2003, 10:48 PM   #8
SassyCassy's guy :P
Well, I did a little reading (ALWAYS a dangerous thing!) and it seems that the idle voltage should be 14 +/- 0.5 volts, so I should be good to go. So long as it is above 12, I am feeding the battery, not draining it. So the new alternator is on hold for the moment. My GFs brother apparently runs an alternator business, so I may swing by his shop later in the week to get it checked out. If I do need to replace it, I suppose I'll put in a 130amp system so I can run underdrives. I'll call it an early x-mas present....
Old 12-02-2003, 03:57 AM   #9
95snoozer
Guest
Posts: n/a
see... never listen to autozone... they are full of shit
oreileys will do you right.... but autozone is as big of scammers as brake check and quick align
Old 12-02-2003, 07:35 PM   #10
MODIFIED
i maybe wrong but i thought all 2nd gen sn95's (99+) had 130amp alts.
MAC CAI, Spintech Dual Side exit exhaust, Prokit, 99 GT Rear Swaybar, AGX 5 way Adj., FRPP Clutch, MM Firewall Adjuster, MM Clutch Quadrant, ASP U/D Pullies,MGW Short Shifter, MGW Billet A/C knobs, MGW Locking Fuel Door, Upgraded Seats, Custom Interior Paint, Interior LED Setup, MM C/C Plates, MM STB, Cobra Brakes, Sequential Turn Signals, Saleen Front Facia, Stalker Hood, Sonic Blue DD Bullitts.
Old 12-03-2003, 11:20 PM   #11
95snoozer
Guest
Posts: n/a
94-95 do
Old 12-04-2003, 08:16 AM   #12
redrum's Avatar
ive had similar thoughts about them as well
Old 12-04-2003, 12:22 PM   #13
MODIFIED
94-95 do
so maybe all sn95's have 130amp alts?
Old 12-04-2003, 03:49 PM   #14
95snoozer
Guest
Posts: n/a
Old 12-05-2003, 05:19 PM   #15
Send a message via AIM to BrittStang 5.0
The rule of thumb I always use is 12+ volts is good with your car off and 13.5+ is good with it running.
<---Black98
BrittStang 5.0 is offline   Reply With Quote
