I need help with Head Gaskets
I need help with picking head gaskets. I Heard that fel pro gaskets are the best. and maybe even copper ones.
here is what my car has 302 - Supercharged CNC Ported E7 "Powerheads" Crane 1.6 roller rocker Crane stud conversion kit New valve springs - good to .600 lift Typhoon Intake 75mm TB and EGR spacer Probe Forged Pistons APR Main Bolts Windage Tray Jay Allen Custom Cam Electric Fan with DCC Controller BBK 1 5/8 shortys UPR o/r X pipe Flowmaster Super 40's Please Help the engine being taken apart as i post this. |
Depending on how much boost you are making , I would go with the Felpro 1011-2's .
I am pretty sure those are the Fel Pro PT9333-1 gaskets and they are good too . I have them on my 410 W .
Does anyone here run the cometic head gaskets?? I ran a set on a few pontiac motors a while back. They are pricey but you can get them in all different sizes and they are great. Im new to ford so not sure what everyone runs but just a suggestion!
Head studs and having the heads O ringed is a good idea when running boost. I have blown a big section out of a new gasket when the heads were O ringed. We had an intresting light show under the hood that night that could be seen through the opening in the rear of the cowl. I use the copper gaskets for my car, but I would not suggest using them with out O ringing the heads. I have heard and seen many people have good results with the factor graphite gaskets which all of Ford's gaskets are made by Felpro. I used only the 1011-2 felpro gaskets before I had my heads O ringed. I have also heard that the Cometic gaskets are good, but I can tell you from experiance that stamped steel gaskets require a very slick head and block surface, Ford use to tell us if you could feel any machining or tool marks by running a finger nail over the surface, it was too corse, it would not seal. I had already found this out the hard way on a few 4.6s and other engines that use stamped steel head gaskets. I would either O ring the heads and get some head studs or get use to changing head gaskets.
Yeah they should work fine as long as you don't go lean on the tune . Kotzur racing heads or Mission should have them in stock .
LoneStarStangs Addict
My theory was I rather pop a gasket than fry a ring, thats why I never used any special types of gasket. It just depends how well your car is tuned and if you know how to work on your own car. Felpro kick ass.
i wish i did. To tell you the truth i have never attempted to work on cars. i just buy them fixed and then sell them when i get tried of them, just like this one. it will be for sell when i get done. looking for a coupe. i have never owned one so i will look for one.
well, the way i look at it i might as well do it right while im there so the person that buys it can have just enough fun as i did!!! this car drives great!!!! paul set this car up right.
Tattoed White Trash
I run a multi layer steel gasket, figure if its good enough for nascar its good enough for me. Cometics have good combustion seal, but heard from a few people running them that they develop coolant leaks.
1991 Calypso Green Coupe-306 Nitrous Motor Best time 11.59, mph 114, 60 ft 1.67-Kaboom! |
#16 |
Professional Leash Holder
Sorry to hear about that, Im suprised a gasket gave out on your. I used the Felpro 9333's. They are great gaskets and come recommeded by people running more boost than the vert. I would either stick with them and switch to head studs instead of the ARP bolts that are there now. Before them, I had the felpro 1011's I believe and had one blow because of fire ring seperation.
#17 |
Jus Workin Away !!!
I ran the Felpro 9333's also..i heard a little trick to was to paint them with high heat silver paint and let it dry, which i did and ARP studded the block, i had no issues whatsoever with that setup...
#18 |
its nice that you have iron heads in this case. I would just run the felpros with that level of boost.
are you shooting for around 350-380 at the wheels? you should be in the neighborhood on a safe tune
