Old 03-05-2008, 10:04 PM   #1
I need help with Head Gaskets
I need help with picking head gaskets. I Heard that fel pro gaskets are the best. and maybe even copper ones.
here is what my car has
302 - Supercharged
CNC Ported E7 "Powerheads"
Crane 1.6 roller rocker
Crane stud conversion kit
New valve springs - good to .600 lift
Typhoon Intake
75mm TB and EGR spacer
Probe Forged Pistons
APR Main Bolts
Windage Tray
Jay Allen Custom Cam
Electric Fan with DCC Controller
BBK 1 5/8 shortys
UPR o/r X pipe
Flowmaster Super 40's
Please Help the engine being taken apart as i post this.
05SILVERGT S/C is offline   Reply With Quote
Old 03-05-2008, 10:19 PM   #2
thesource's Avatar
Trader Rating: (13)
Depending on how much boost you are making , I would go with the Felpro 1011-2's .
Old 03-05-2008, 10:20 PM   #3
I have the FRPP graphite's on mine.
Old 03-05-2008, 10:23 PM   #4
thesource's Avatar
Trader Rating: (13)
I am pretty sure those are the Fel Pro PT9333-1 gaskets and they are good too . I have them on my 410 W .
Old 03-05-2008, 10:27 PM   #5
Does anyone here run the cometic head gaskets?? I ran a set on a few pontiac motors a while back. They are pricey but you can get them in all different sizes and they are great. Im new to ford so not sure what everyone runs but just a suggestion!
Razor81 is offline   Reply With Quote
Old 03-05-2008, 10:32 PM   #6
I heard good things about the Cometic gaskets. Although i don't know anyone who runs them personally.
Old 03-05-2008, 10:38 PM   #7
Sonic Blue 85's Avatar
Head studs and having the heads O ringed is a good idea when running boost. I have blown a big section out of a new gasket when the heads were O ringed. We had an intresting light show under the hood that night that could be seen through the opening in the rear of the cowl. I use the copper gaskets for my car, but I would not suggest using them with out O ringing the heads. I have heard and seen many people have good results with the factor graphite gaskets which all of Ford's gaskets are made by Felpro. I used only the 1011-2 felpro gaskets before I had my heads O ringed. I have also heard that the Cometic gaskets are good, but I can tell you from experiance that stamped steel gaskets require a very slick head and block surface, Ford use to tell us if you could feel any machining or tool marks by running a finger nail over the surface, it was too corse, it would not seal. I had already found this out the hard way on a few 4.6s and other engines that use stamped steel head gaskets. I would either O ring the heads and get some head studs or get use to changing head gaskets.
Old 03-05-2008, 11:44 PM   #8
i think car is pushing 8lb of boost. would the Felpro 1011-2's .be the best choice and where do i get them.
Old 03-05-2008, 11:52 PM   #9
thesource's Avatar
Trader Rating: (13)
Yeah they should work fine as long as you don't go lean on the tune . Kotzur racing heads or Mission should have them in stock .
Old 03-06-2008, 12:04 AM   #10
LoneStarStangs Addict
Allnuts's Avatar
Trader Rating: (-1)
My theory was I rather pop a gasket than fry a ring, thats why I never used any special types of gasket. It just depends how well your car is tuned and if you know how to work on your own car. Felpro kick ass.
Old 03-06-2008, 12:17 AM   #11
i wish i did. To tell you the truth i have never attempted to work on cars. i just buy them fixed and then sell them when i get tried of them, just like this one. it will be for sell when i get done. looking for a coupe. i have never owned one so i will look for one.
Old 03-06-2008, 12:22 AM   #12
Allnuts's Avatar
Trader Rating: (-1)
If thats the case, then I wouldn't pour much money into head gaskets
Old 03-06-2008, 12:37 AM   #13
well, the way i look at it i might as well do it right while im there so the person that buys it can have just enough fun as i did!!! this car drives great!!!! paul set this car up right.
Old 03-06-2008, 12:47 AM   #14
Allnuts's Avatar
Trader Rating: (-1)
True.
Old 03-06-2008, 09:39 AM   #15
Tattoed White Trash
HISS1998's Avatar
I run a multi layer steel gasket, figure if its good enough for nascar its good enough for me. Cometics have good combustion seal, but heard from a few people running them that they develop coolant leaks.
1991 Calypso Green Coupe-306 Nitrous Motor
Best time 11.59, mph 114, 60 ft 1.67-Kaboom!
HISS1998 is offline   Reply With Quote
Old 03-06-2008, 10:19 AM   #16
Professional Leash Holder
TheBocSez's Avatar
Sorry to hear about that, Im suprised a gasket gave out on your. I used the Felpro 9333's. They are great gaskets and come recommeded by people running more boost than the vert. I would either stick with them and switch to head studs instead of the ARP bolts that are there now. Before them, I had the felpro 1011's I believe and had one blow because of fire ring seperation.
Old 03-06-2008, 03:52 PM   #17
Jus Workin Away !!!
txlen's Avatar
I ran the Felpro 9333's also..i heard a little trick to was to paint them with high heat silver paint and let it dry, which i did and ARP studded the block, i had no issues whatsoever with that setup...
Old 03-06-2008, 05:52 PM   #18
its nice that you have iron heads in this case. I would just run the felpros with that level of boost.
are you shooting for around 350-380 at the wheels? you should be in the neighborhood on a safe tune
Old 03-06-2008, 06:02 PM   #19
FOUND OUT IT WAS THE INTAKE GASKET!!!! OH WELL THE HEADS ARE OFF!!!
